Creating a Dedicated BMS
Resources in a DeC are physically isolated from those in public resource pools. If your services have high security compliance requirements, you can create BMSs in a DeC in either of the following ways:
Before creating a BMS in a DeC, you must apply for a dedicated BMS resource pool.
You have enabled DeC. For details, see Enabling a DeC.
Apply for a Dedicated BMS Pool
- Click the region name in the upper left corner and select the region where DeC resides from the drop-down list.
Figure 1 Selecting the region where DeC resides
- Choose Service List > Dedicated Cloud > Dedicated Bare Metal Server.
The Dedicated Bare Metal Server page is displayed.
- In the upper right corner, click Apply for Resources.
- Select a flavor based on your service requirements and set the quantity and usage duration.
- Click Next. After confirming that the configurations are correct, click Submit.
Message Request submitted successfully. is displayed. The application will be reviewed by the O&M personnel. After the application is approved, you can choose Fees > My Orders and pay the order.
- After paying the order, you can view information about the resource pool on the Dedicated Bare Metal Server page, such as Resource Pool Type, CPU Allocation Rate, and Memory Allocation Rate.
Method 1: Create a Dedicated BMS on the DeC Console
- In the upper right corner of the page, click Provision BMS in DeC.
The page for creating a BMS is displayed.
- Set the parameters as prompted. These parameters are the same as those for creating a common BMS. For details, see Creating a Common BMS.
After the BMS is created, the number of BMSs on the Dedicated Bare Metal Server page becomes 1, and CPU Allocation Rate and Memory Allocation Rate increase.
Method 2: Create a Dedicated BMS on the Cloud Server Console
- Choose Service List > Computing > Bare Metal Server.
The Cloud Server Console is displayed.
- On the BMS page, click Provision BMS in DeC in the upper right corner.
After the BMS is displayed, click the BMS Resource Pool tab in the Resource Usage Details area on the Dashboard page. The number of BMSs is 1, and CPU Allocation Rate and Memory Allocation Rate increase.
Provide feedbackFor any further questions, feel free to contact us through the chatbot.
