Creating a BMS from a Private Image
If you want to create a BMS that has the same OS and applications as an existing BMS, you can create a private image using the existing BMS and then create a BMS using the private image. This frees you from repeatedly configuring BMSs and improves efficiency.
Create a BMS by following the instructions in Creating a Custom BMS.
Note for setting the parameters:
- Region: Select the region where the private image is located.
- Flavor: OSs supported by different BMS flavors vary. For details, see OSs Supported by Different Types of BMSs. Select a flavor based on the private image OS.
- Image: Select Private image or Shared image and select the required image from the drop-down list.
- Disk: If the selected flavor supports quick provisioning, you are advised to increase System Disk by 2 GB or more.
