Debugging BPMs
Flows and BPMs both feature a log tracer that tracks step inputs and outputs, ensuring process performance matches your expectation.
Debugging a BPM
- Log in to the application designer by referring to Logging In to the Application Designer.
- In the navigation pane, choose BPMs.
- Move the cursor to
of the corresponding BPM, and choose Edit.
- To simulate BPM interactions, click
to run the BPM from the design page.
After the simulation, verify the results to ensure they align with your expectation.
- Click Tracer in the upper right corner of the design page.
- On the log tracer page, view details about each step in the BPM, for example, check whether variables are transferred as expected.
Figure 1 Log tracer
The log tracer page is divided into two sections: a search box and a log tracing table.
- Search box
Figure 2 Search box
- BPM switchover: allows you to filter BPMs by start time. The tracing information is stored for 30 minutes.
- Search box: allows you to search BPMs using the tracing information.
- Download button: allows you to download and save the complete logs as a file to your local PC.
- Table: records BPM process logs with timestamps, module types and names, element types and names, and operation descriptions. During subprocess execution, the module reflects the subprocess details.
- Search box
- If the result does not meet your expectation, return to the BPM and repeat 4.
Common Errors
- Incorrect variables
Verify input parameter types match definitions and convert types if needed.
- Incorrect variable structures
Ensure input parameter structures (such as attribute name or value type) match the target. For extensive JSON errors, use JSON viewers or formatters to compare.
- Unspecified branches and unexpected termination
Ensure a default branch is set in exclusive gateways to prevent process termination when all conditions are unmet. The process ends implicitly when no next steps are defined.
