x-apigateway-backend.httpVpcMemberGroupEndpoints
Meaning: HTTP VPC backend service definition. It is restricted. To use it, submit a service ticket.
Scope of effect: x-apigateway-backend
Example:
paths:
'/users/{userId}':
get:
produces:
- "application/json"
parameters:
- name: "X-Auth-Token"
description: "Authentication token"
type: "string"
in: "header"
required: true
responses:
default:
description: "default response"
x-apigateway-request-type: "public"
x-apigateway-backend:
type: "HTTP-VPC-MEMBER-GROUP"
httpVpcMemberGroupEndpoints:
memberGroupUrlInfos:
- name: "xxxxx"
scheme: "http"
method: "GET"
path: "/users"
enableClientSsl:false
enableSmChannel: false
retryCount: 0
timeout: 5000
Parameter |
Mandatory |
Type |
Description |
memberGroupUrlInfos |
Yes |
x-apigateway-backend.httpVpcMemberGroupEndpoints.memberGroupUrlInfos |
URL of a server group. |
name |
Yes |
String |
Load balance channel name. It can contain 3 to 64 characters, starting with a letter. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed. Chinese characters must be in UTF-8 or Unicode format. |
timeout |
No |
Number |
Backend request timeout in milliseconds. The value ranges from 1 to 60,000, and the default value is 5000. |
retryCount |
No |
String |
Number of retry attempts to request the backend service. The default value is –1. The value ranges from –1 to 10. –1 indicates that idempotent APIs will retry once and non-idempotent APIs will not retry. POST and PATCH are non-idempotent. GET, HEAD, PUT, OPTIONS, and DELETE are idempotent. Default value: -1 |
enableClientSsl |
No |
Boolean |
Indicates whether to enable two-way authentication. |
enableSmChannel |
No |
Boolean |
Indicates whether to enable SM cryptographic algorithms. This feature is only available if the gateway supports the SM cryptographic algorithms. |
