x-apigateway-backend.httpVpcMemberGroupEndpoints.memberGroupUrlInfos
Meaning: HTTP VPC backend service definition. It is restricted. To use it, submit a service ticket.
Scope of effect: x-apigateway-backend
Example:
paths:
'/users/{userId}':
get:
produces:
- "application/json"
parameters:
- name: "X-Auth-Token"
description: "Authentication token"
type: "string"
in: "header"
required: true
responses:
default:
description: "default response"
x-apigateway-request-type: "public"
x-apigateway-backend:
type: "HTTP-VPC-MEMBER-GROUP"
httpVpcMemberGroupEndpoints:
memberGroupUrlInfos:
- name: "xxxxx"
scheme: "http"
method: "GET"
path: "/users"
enableClientSsl: false
enableSmChannel: false
retryCount: 0
timeout: 5000
Parameter |
Mandatory |
Type |
Description |
scheme |
Yes |
String |
Backend request protocol. HTTP and HTTPS are supported. |
method |
Yes |
String |
Backend request method. The options include GET, POST, PUT, DELETE, HEAD, OPTIONS, PATCH, and ANY. |
path |
Yes |
String |
Request address, which can contain request parameters enclosed with braces ({}). For example, /getUserInfo/{userId}. Special characters, such as asterisks (*), slashes (/), percent signs (%), hyphens (-), underscores (_), and periods (.), are allowed. It can contain a maximum of 512 characters and must comply with URI specifications. Environment variables are supported. Each must start with a letter and can consist of 3 to 32 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed. |
name |
Yes |
String |
Name of the VPC channel's backend server group. It can contain 3 to 64 characters, starting with a letter. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. Chinese characters must be in UTF-8 or Unicode format. |
