x-apigateway-backend.functionEndpoints
Meaning: Function backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      parameters:
        - name: "X-Auth-Token"
          description: "Authentication token"
          type: "string"
          in: "header"
          required: true
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "FUNCTION"
        functionEndpoints:
          version: "v1"
          function-urn: ""
          invocation-type: "synchronous"
          timeout: 30000
       Parameter  |
       Mandatory  |
       Type  |
       Description  |
       function-urn  |
       Yes  |
       String  |
       Function URN.  |
       version  |
       Yes  |
       String  |
       Function version.  |
       invocation-type  |
       Yes  |
       String  |
       Function invocation type. The value can be asynchronous or synchronous.  |
       timeout  |
       No  |
       Number  |
       Function timeout in milliseconds. The value ranges from 1 to 60,000, and the default value is 5000.  |
