Updating a Template or Parameter
For stack deployment, stack change records are not provided. Exercise caution when performing this operation. If you want to view change details, you are advised to create an execution plan.
You can add cloud service resources or change resource specifications in either of the following ways: Go to the stack list page, locate the target stack, and click Update in the Operation column. Alternatively, go to the stack details page and click Update Template/Parameter in the upper right corner to enter the page for updating the stack, as shown in Figure 1.
You can select Current Template or Replace Current Template (use a new template) to update the stack.
Solution 1: Using the Current Template
- Click Next to go to the Configure Parameters page and modify parameters, as shown in Figure 2.
- Click Next to go to the Confirm Configurations page, as shown in Figure 3.
- Click Directly Deploy Stack. The Events page is displayed.
The status changes to Update Complete, as shown in Figure 4.
Solution 2: Replacing the Current Template (refer to Creating a Stack.)
