Updated on 2024-01-23 GMT+08:00
Partition-related Syntax
- Adding Partition Data (Only OBS Tables Supported)
- Renaming a Partition (Only OBS Tables Supported)
- Deleting a Partition
- Deleting Partitions by Specifying Filter Criteria (Only Supported on OBS Tables)
- Altering the Partition Location of a Table (Only OBS Tables Supported)
- Updating Partitioned Table Data (Only OBS Tables Supported)
- Updating Table Metadata with REFRESH TABLE
Parent topic: Tables
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
