Uploading an Object - Asynchronous Resumable Upload
Function
The resumable upload is an encapsulated and enhanced version of the multipart upload used for dealing with possible upload failures of large files when the network connection is unstable or a program crashes. This API splits the file into multiple parts and uploads them individually. The upload result of each part is recorded in a checkpoint file in real time. A success message is returned only when all parts are uploaded. If any parts fail, an error message is returned telling you to call the API again to upload the failed parts. Since the checkpoint file contains the progress of each part, it saves you uploading all parts again in the event of an error.
This API is used for asynchronous resumable upload. Compared with synchronous resumable upload (see Uploading an Object - Resumable (SDK for Go)), this API allows you to pause, resume, or cancel the upload.
If you need to pause, resume, or cancel the upload, you are advised to use this API. Otherwise, you are advised to use the synchronous resumable upload API, which is easier to use.
Restrictions
- To upload an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- The file uploaded by the resumable upload API must be larger than 100 KB in size.
- When the resumable upload API is used, this option should be enabled so that the progress of the last upload can be read for entering the process again.
Method
func (obsClient ObsClient) UploadFileAsync(input *UploadFileInput, extensions ...extensionOptions) (task *TransferTask, err error)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| input | Yes | Explanation: Input parameters for a resumable upload. For details, see Table 2. |
| Bucket | string | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| Key | string | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| UploadFile | string | Yes | Explanation: Local file path of the object to be uploaded Default value: None |
| PartSize | int64 | Yes | Explanation: Part size Value range: The value ranges from 100 KB to 5 GB, in bytes. Default value: 102400 |
| TaskNum | int | No | Explanation: Maximum number of parts that can be uploaded concurrently Value range: An integer from 1 to 10000 Default value: 1, indicating concurrent uploads are not used |
| EnableCheckpoint | bool | No | Explanation: Whether to enable the resumable upload Value range: true: The resumable upload mode is enabled. false: The resumable upload mode is disabled. Default value: false |
| CheckpointFile | string | No | Explanation: File used to record the upload progress. This parameter is valid only in the resumable upload mode. Default value: If this parameter is left blank, the progress file will be in the same directory as the local file to be uploaded. |
| ACL | No | Explanation: ACL that can be pre-defined during object creation. For details about the ACL, see ACLs. Value range: For details about the ACL options, see AclType. Default value: None | |
| WebsiteRedirectLocation | string | No | Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. The request is redirected to object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
| ContentType | string | No | Explanation: MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? Default value: If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter. |
| SseHeader | No | Explanation: Server-side encryption header information. If SSE-C is used, see Table 4. If SSE-KMS is used, see Table 5. | |
| StorageClass | No | Explanation: Object storage class Value range: See Table 6. Default value: If this parameter is not specified, the object inherits the storage class of the bucket. | |
| Metadata | map[string]string | No | Explanation: Custom metadata of the object to be uploaded. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
| Expires | int64 | No | Explanation: Expiration time of the object (calculated from the latest modification time of the object). Expired objects are automatically deleted. Value range: 1 to (263 - 1), in days Default value: None |
| GrantReadId | string | No | Explanation: ID (domain_id) of an account the READ permission is granted to. The account with the READ permission can read the current object and obtain its metadata. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| GrantReadAcpId | string | No | Explanation: ID (domain_id) of an account the READ_ACP permission is granted to. The account with the READ_ACP permission can read the ACL of the current object. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| GrantWriteAcpId | string | No | Explanation: ID (domain_id) of an account the WRITE_ACP permission is granted to. The account with the WRITE_ACP permission can write the ACL of the current object. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| GrantFullControlId | string | No | Explanation: ID (domain_id) of an account the FULL_CONTROL permission is granted to. The account with the FULL_CONTROL permission can read the current object, obtain its metadata, and obtain and write its ACL. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| EncodingType | string | No | Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
| Constant | Default Value | Description |
| AclPrivate | private | Private read/write A bucket or object can only be accessed by its owner. |
| AclPublicRead | public-read | Public read and private write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket. If it is granted on an object, anyone can read the content and metadata of the object. |
| AclPublicReadWrite | public-read-write | Public read/write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If it is granted on an object, anyone can read the content and metadata of the object. |
| AclPublicReadDelivered | public-read-delivered | Public read on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions, and read the content and metadata of objects in the bucket. NOTE: AclPublicReadDelivered does not apply to objects. |
| AclPublicReadWriteDelivered | public-read-write-delivered | Public read/write on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket. NOTE: AclPublicReadWriteDelivered does not apply to objects. |
| AclBucketOwnerFullControl | bucket-owner-full-control | If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. |
| Encryption | string | Yes if used as a request parameter | Explanation: SSE-C used for encrypting objects Restrictions: None Value range: AES256, indicating objects are encrypted using SSE-C Default value: None |
| Key | string | Yes if used as a request parameter | Explanation: Key for encrypting the object when SSE-C is used Restrictions: The value is a Base64-encoded 256-bit key, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=. Value range: None Default value: None |
| KeyMD5 | string | No if used as a request parameter | Explanation: MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Value range: None Default value: None |
| Encryption | string | Yes if used as a request parameter | Explanation: SSE-KMS is used for encrypting objects on the server side. Value range: kms Default value: None |
| Key | string | No if used as a request parameter | Explanation: ID of the KMS master key when SSE-KMS is used Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
| ProjectID | string | No if used as a request parameter | Explanation: ID of the project (not an enterprise project) where the KMS CMK belongs when SSE-KMS is used Restrictions: None Value range: Project ID (not enterprise project ID) that matches the key ID specified by Key. Default value: None |
| StorageClassStandard | STANDARD | OBS Standard Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
| StorageClassWarm | WARM | OBS Infrequent Access Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
| StorageClassCold | COLD | OBS Archive Used for storing rarely accessed (once a year) data. |
Responses
| Method | Description |
| Status() TransferStatusType | Obtains the status of the current task. |
| Pause() error | Pauses the task. |
| Resume() error | Resumes the task. |
| Cancel() error | Cancels the task. |
| Done() <-chan struct{} | Obtains the completion signal channel. |
| GetResult() (interface{}, error) | Obtains the upload result. |
After the upload is successful, use GetResult () to obtain the result. CompleteMultipartUploadOutput is returned.
| Field | Type | Description |
| VersionId | string | Object version ID (available in a versioning-enabled bucket). |
| ETag | string | ETag of the object. |
| Location | string | Bucket location. |
| Bucket | string | Bucket name. |
| Key | string | Object key. |
Sample Code
Example 1: This example uses the asynchronous resumable method to upload local file example to bucket examplebucket as an object named new-example.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 | package main import ( "fmt" "log" "os" ) func main() { // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint /*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } // Prepare the input for upload. input := &obs.UploadFileInput{} input.Bucket = "examplebucket" input.Key = "new-example" input.UploadFile = "/path/to/local/example" input.PartSize = 10 * 1024 * 1024 // 10MB input.TaskNum = 3 // Three concurrent tasks // Start asynchronous upload. task, err := obsClient.UploadFileAsync(input) if err != nil { log.Fatal(err) } // Wait until the upload is complete. <-task.Done() // Obtain the upload result. result, err := task.GetResult() if err != nil { fmt.Printf("Upload failed: %v\n", err) return } output := result.(*obs.CompleteMultipartUploadOutput) fmt.Printf("Upload succeeded.\nETag: %s\nVersionId: %s\n", output.ETag, output.VersionId) } |
Example 2: This example uses the asynchronous resumable method to upload local file example to bucket examplebucket as an object named new-example and obtains the upload progress through callback.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 | package main import ( "fmt" "log" "os" ) // Progress listener type ProgressListener struct{} func (l *ProgressListener) ProgressChanged(event *obs.ProgressEvent) { switch event.EventType { case obs.TransferStartedEvent: fmt.Printf("Upload started. Total size: %d bytes\n", event.TotalBytes) case obs.TransferDataEvent: percent := float64(event.ConsumedBytes) / float64(event.TotalBytes) * 100 fmt.Printf("Uploading: %.2f%% (%d/%d bytes)\n", percent, event.ConsumedBytes, event.TotalBytes) case obs.TransferCompletedEvent: fmt.Println("Upload completed.") case obs.TransferFailedEvent: fmt.Printf("Upload failed: %d/%d bytes transferred.\n", event.ConsumedBytes, event.TotalBytes) } } func main() { // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint /*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.UploadFileInput{} input.Bucket = "examplebucket" input.Key = "new-example" input.UploadFile = "/path/to/local/example" input.PartSize = 10 * 1024 * 1024 input.TaskNum = 3 // Add a progress listener. task, err := obsClient.UploadFileAsync(input, obs.WithProgress(&ProgressListener{})) if err != nil { log.Fatal(err) } // Wait until the task is complete. <-task.Done() result, err := task.GetResult() if err != nil { fmt.Printf("Upload failed: %v\n", err) return } output := result.(*obs.CompleteMultipartUploadOutput) fmt.Printf("Upload succeeded. ETag: %s\n", output.ETag) } |
Example 3: This example suspends and resumes an asynchronous resumable upload.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 | package main import ( "fmt" "log" "os" "time" ) func main() { // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint /*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.UploadFileInput{} input.Bucket = "examplebucket" input.Key = "new-example" input.UploadFile = "/path/to/local/example" input.PartSize = 10 * 1024 * 1024 input.TaskNum = 3 task, err := obsClient.UploadFileAsync(input) if err != nil { log.Fatal(err) } // Pause the upload task after 5 seconds of execution. go func() { time.Sleep(5 * time.Second) // If the upload is complete within 5 seconds, no pause is required. Handle this case separately. if task.Status() == obs.TransferStatusCompleted { fmt.Println("The upload is complete within 5 seconds. No pause is required.") return } fmt.Println("Pausing the upload...") err := task.Pause() if err != nil { fmt.Printf("Pause failed: %v\n", err) } else { fmt.Println("Upload paused.") } }() // Wait until the task is paused or completed. (If the task is completed, the system does not wait for the task to be paused to avoid an infinite loop.) for task.Status() != obs.TransferStatusPaused && task.Status() != obs.TransferStatusCompleted { time.Sleep(100 * time.Millisecond) } // If the task is complete, skip the pause and resumption processes. No further action is required. if task.Status() == obs.TransferStatusCompleted { fmt.Println("Current status: completed. The pause and resumption are skipped.") } else { fmt.Println("Current status: paused.") // Resume the task after 3 seconds of pause. time.Sleep(3 * time.Second) // The task may have been completed during the pause. If the task has been completed, skip the resumption to avoid calling Resume for a completed task. if task.Status() == obs.TransferStatusCompleted { fmt.Println("The upload has been completed during the pause. The resumption process is skipped.") } else { fmt.Println("Resuming upload...") err = task.Resume() if err != nil { fmt.Printf("Resumption failed: %v\n", err) } else { fmt.Println("Upload resumed.") } } } // Wait until the task is complete. <-task.Done() result, err := task.GetResult() if err != nil { fmt.Printf("Upload failed: %v\n", err) return } output := result.(*obs.CompleteMultipartUploadOutput) fmt.Printf("Upload succeeded. ETag: %s\n", output.ETag) } |
Example 4: This example cancels an asynchronous resumable upload.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 | package main import ( "fmt" "log" "os" "time" ) func main() { // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint /*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.UploadFileInput{} input.Bucket = "examplebucket" input.Key = "new-example" input.UploadFile = "/path/to/local/example" input.PartSize = 10 * 1024 * 1024 input.TaskNum = 3 task, err := obsClient.UploadFileAsync(input) if err != nil { log.Fatal(err) } // Cancel the upload task after 5 seconds of execution. go func() { time.Sleep(5 * time.Second) fmt.Println("Canceling the upload...") err := task.Cancel() if err != nil { fmt.Printf("Failed to cancel the upload: %v\n", err) } else { fmt.Println("Upload canceled.") } }() // Wait until the task is complete or canceled. <-task.Done() // Check the result. result, err := task.GetResult() if err != nil { if err.Error() == "upload task cancelled" { fmt.Println("Upload canceled by the user.") } else { fmt.Printf("Upload failed: %v\n", err) } return } output := result.(*obs.CompleteMultipartUploadOutput) fmt.Printf("Upload succeeded. ETag: %s\n", output.ETag) } |
