Updated on 2026-10-30 GMT+08:00
Uploading an Object - Append (SDK for Go)
Function
This API uploads a file or folder to an existing OBS bucket. You can upload texts, videos, or any other types of files.
The AppendObject operation adds data to the end of an object in a specified bucket. If there is no namesake object in the bucket, a new object is created.
Restrictions
  • To upload an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • Uploaded objects are stored in buckets. Only the users who have the write permission can upload objects to buckets. The name of each object in a bucket must be unique.
  • The last modification time of the object is updated each time an append upload is performed.
  • If the server-side encryption (SSE-C) is used, the append upload is the same as the multipart initialization. The request header such as x-obs-server-side-encryption should be carried for each append upload.
  • If the KMS server-side encryption (SSE-KMS) is used, the request header such as x-obs-server-side-encryption should be carried only when the object is uploaded for the first time and no object with the same name exists in the bucket.
  • The length of each append upload cannot exceed the upper limit (5 GB) of the object length.
  • The maximum number of append writes for each appendable object is 10,000.
  • If the storage class is COLD (Archive), this API cannot be called.
  • If cross-region replication is configured for a bucket, this API cannot be called.
  • Object appending is not available for parallel file systems.
Method
func (obsClient ObsClient) AppendObject(input *AppendObjectInput) (output *AppendObjectOutput, err error)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
input
*AppendObjectInput
Yes
Explanation:
Request parameters for an append upload. For details, see Table 2.
Table 2 AppendObjectInput
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
Position
int64
Yes
Explanation:
Position where the object data is appended
Restrictions:
For an object to be appended, the value of position must be set to 0 when the object is uploaded for the first time. For the second append upload, the value of position should be set to the value of NextAppendPosition returned in the response when the first upload is successful.
Value range:
0 to (263 – 1), in bytes
Default value:
0
ContentMD5
string
No
Explanation:
Base64-encoded MD5 value of the object data to be uploaded. It is provided for the OBS server to verify data integrity.
Value range:
ContentMD5 contains the Base64-encoded 128-bit MD5 digest calculated according to RFC 1864.
Example: n58IG6hfM7vqI4K0vnWpog==
Default value:
None
ACL
AclType
No
Explanation:
ACL that can be pre-defined during object creation. For details about the ACL, see ACLs.
Value range:
For details about the ACL options, see AclType.
Default value:
None
WebsiteRedirectLocation
string
No
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL.
The request is redirected to an object anotherPage.html in the same bucket:
WebsiteRedirectLocation:/anotherPage.html
The request is redirected to an external URL http://www.example.com/:
WebsiteRedirectLocation:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection for objects in the root directory of a bucket.
Default value:
None
ContentType
string
No
Explanation:
MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Value range:
See What Is Content-Type (MIME)?
Default value:
If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter.
ContentLength
int64
No
Explanation:
Size of the object to be uploaded
Restrictions:
  • The object size in a single upload ranges from 0 to 5 GB.
  • To upload files larger than 5 GB, multipart uploads should be used.
Default value:
If this parameter is not specified, the SDK automatically calculates the size of the object.
SseHeader
SseCHeader or SseKmsHeader
No
Explanation:
Server-side encryption header information. If SSE-C is used, see Table 4. If SSE-KMS is used, see Table 5.
StorageClass
StorageClassType
No
Explanation:
Object storage class
Value range:
See Table 6.
Default value:
If you do not specify this header, the object inherits the storage class of the bucket.
Metadata
map[string]string
No
Explanation:
Custom metadata of the object to be uploaded. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata.
Restrictions:
  • The custom metadata cannot exceed 8 KB. To measure the custom metadata, sum the number of bytes in the UTF-8 encoding of each key and value.
  • The custom metadata keys are case insensitive, but are stored in lowercase in OBS. The key values are case sensitive.
  • Both custom metadata keys and their values must conform to US-ASCII standards. If non-ASCII or unrecognizable characters are required, they must be encoded and decoded in URL or Base64 on the client, because the server does not perform such operations.
Default value:
None
Body
io.Reader
No
Explanation:
Data stream of the object to be uploaded
Restrictions:
Default value:
None
GrantReadId
string
No
Explanation:
ID (domain_id) of an account the READ permission is granted to. The account with the READ permission can read the current object and obtain its metadata.
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
GrantReadAcpId
string
No
Explanation:
ID (domain_id) of an account the READ_ACP permission is granted to. The account with the READ_ACP permission can read the ACL of the current object.
Value range:
Default value:
None
GrantWriteAcpId
string
No
Explanation:
ID (domain_id) of an account the WRITE_ACP permission is granted to. The account with the WRITE_ACP permission can write the ACL of the current object.
Value range:
Default value:
None
GrantFullControlId
string
No
Explanation:
ID (domain_id) of an account the FULL_CONTROL permission is granted to. The account with the FULL_CONTROL permission can read the current object, obtain its metadata, and obtain and write its ACL.
Value range:
Default value:
None
Expires
int64
No
Explanation:
Expiration time of the object (calculated from the latest modification time of the object). Expired objects are automatically deleted.
Value range:
1 to (263 - 1), in days
Default value:
None
Table 3 AclType
Constant
Default Value
AclPrivate
private
Private read/write
A bucket or object can only be accessed by its owner.
AclPublicRead
public-read
Public read and private write
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket.
If it is granted on an object, anyone can read the content and metadata of the object.
AclPublicReadWrite
public-read-write
Public read/write
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks.
AclPublicReadDelivered
public-read-delivered
Public read on a bucket as well as objects in the bucket
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions, and read the content and metadata of objects in the bucket.
AclPublicReadDelivered does not apply to objects.
AclPublicReadWriteDelivered
public-read-write-delivered
Public read/write on a bucket as well as objects in the bucket
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket.
AclPublicReadWriteDelivered does not apply to objects.
AclBucketOwnerFullControl
bucket-owner-full-control
If this permission is granted on an object, only the bucket and object owners have the full control over the object.
By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object.
Table 4 SseCHeader
Type
Mandatory (Yes/No)
Encryption
string
Yes if used as a request parameter
Explanation:
SSE-C used for encrypting objects
Restrictions:
None
Value range:
AES256, indicating objects are encrypted using SSE-C
Default value:
None
Key
string
Explanation:
Key for encrypting the object when SSE-C is used
Restrictions:
The value is a Base64-encoded 256-bit key, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=.
Value range:
None
Default value:
None
KeyMD5
string
No if used as a request parameter
Explanation:
MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key.
Restrictions:
The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==.
Value range:
None
Default value:
None
Table 5 SseKmsHeader
Type
Mandatory (Yes/No)
Encryption
string
Explanation:
SSE-KMS is used for encrypting objects on the server side.
Value range:
kms
Default value:
None
Key
string
Explanation:
ID of the KMS master key when SSE-KMS is used
Value range:
Valid value formats are as follows:
  1. regionID:domainID:key/key_id
  2. key_id
In the preceding formats:
Default value:
  • If this parameter is not specified, the default master key will be used.
  • If there is no such a default master key, OBS will create one and use it by default.
ProjectID
string
Explanation:
ID of the project (not an enterprise project) where the KMS CMK belongs when SSE-KMS is used
Restrictions:
None
Value range:
Project ID (not enterprise project ID) that matches the key ID specified by Key.
Default value:
None
Table 6 StorageClassType
Constant
Default Value
StorageClassStandard
STANDARD
OBS Standard
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
StorageClassWarm
WARM
OBS Infrequent Access
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
StorageClassCold
COLD
OBS Archive
Used for storing rarely accessed (once a year) data.
Responses
Table 7 List of returned results
Type
output
*AppendObjectOutput
Explanation:
Returned results. For details, see Table 8.
err
error
Explanation:
Error messages returned by the API
Table 8 AppendObjectOutput
Type
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
VersionId
string
Explanation:
Object version ID. If versioning is enabled for the bucket, the object version ID will be returned.
Value range:
The value must contain 32 characters.
Default value:
None
ETag
string
Explanation:
Base64-encoded, 128-bit MD5 value of the object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if ETag value is A when an object is uploaded but changes to B when the object is downloaded, it indicates that the object content is changed. The ETag reflects changes to the object content, rather than the object metadata. An uploaded object or copied object has a unique ETag.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
Default value:
None
SseHeader
Explanation:
Server-side encryption header information. If SSE-C is used, see Table 9. If SSE-KMS is used, see Table 10.
NextAppendPosition
int64
Explanation:
Position from which the next append upload starts
Restrictions:
Value range:
Default value:
0
Table 9 SseCHeader
Type
Mandatory (Yes/No)
Encryption
string
Explanation:
Restrictions:
None
Value range:
Default value:
None
Key
string
Explanation:
Restrictions:
Value range:
None
Default value:
None
KeyMD5
string
Explanation:
Restrictions:
Value range:
None
Default value:
None
Table 10 SseKmsHeader
Type
Mandatory (Yes/No)
Encryption
string
Explanation:
Value range:
kms
Default value:
None
Key
string
Explanation:
Value range:
  2. key_id
Default value:
ProjectID
string
Explanation:
Restrictions:
None
Value range:
Default value:
None
Code Examples
This example appends data to object example/objectname in bucket examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
package main
import (
    "fmt"
    "os"
    "strings"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken))
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.AppendObjectInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify the object (example/objectname as an example) to append content to.
    input.Key = "example/objectname"
    // Specify the position where content is appended. Position must be set to 0 for the first append upload.
    input.Position = 0
    // Specify data streams of the object to upload.
    input.Body = strings.NewReader("Hello OBS")
    // Append content to the object.
    output, err := obsClient.AppendObject(input)
    if err == nil {
        fmt.Printf("Append object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket)
        fmt.Printf("ETag:%s, NextAppendPosition:%d\n", output.ETag, output.NextAppendPosition)
        return
    fmt.Printf("Append objects under the bucket(%s) fail!\n", input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
    } else {
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
