- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Application Scenarios
O&M Situation Awareness BI Dashboard
The dedicated O&M BI dashboard caters to various O&M roles, aiding in optimization, insight generation, and decision-making.
Rich metrics: COC provides 30+ preset O&M metrics, delivering insights into your cloud resources across seven perspective-based dashboards and a comprehensive enterprise-level O&M sandbox.
Full-Lifecycle Resource Management
Full-lifecycle resource management is available, and includes actions such as resource defining, requesting, provisioning, O&M, changing, configuration, renewal, and recycling; building a unified resource management center.
- Full-lifecycle management: eliminates breakpoints across the entire user resource management journey, ensuring smooth user resource management and efficient O&M.
- Resource management center: enables visualized management of your resources from a global perspective, and supports multi-cloud and cross-account centralized O&M.
Change Risk Control and Operations Trustworthiness
Management and control models that integrate Huawei SRE best practices in secure production provide you with trustworthy, stable, and reliable O&M capabilities.
- All-round operations trustworthiness ensures operational security before, during, and after changes, is supported by personnel risk assessment capabilities, and offers high-risk command alerts, and automated inspection.
- AI-powered risk assessment: The intelligent interception algorithm for high-risk commands is used to mitigate operation risks.
Standardized Fault Management
- Standard process: provides a standardized troubleshooting process on Huawei Cloud. Bolstered by contingency plans and the WarRoom-based synergy of O&M engineers, R&D teams, and other personnel, this standardized process helps you handle faults encountered with ease.
- O&M knowledge base: enables the swift handling of faults. A rich repository of O&M knowledge, derived from handling historical faults and the accumulation of experience in handling unknown faults, increases efficiency during fault handling process.
Intelligent Chaos Drills
- E2E chaos engineering solutions: provide E2E chaos drill capabilities based on your service scenarios from four dimensions: risk analysis, contingency plans, drill execution, and drill review.
- Failure mode library: introduces the methodology of analyzing fault scenarios from the perspective of fault tolerance, and leverages Huawei Cloud SREs' years of accumulated experience in fault handling through the failure mode library.
