Billing Modes
Overview
COC provides two billing modes: yearly/monthly and pay-per-use.
- Yearly/Monthly billing is a prepaid mode, in which you pay for the service before using it. Your bill is settled based on the subscription period. The longer the subscription term, the higher the discount. This mode is a good option for long-term, stable services.
- Pay-per-use billing is a postpaid mode. In this mode, you pay for what you used. This mode allows you to adjust resource usage easily. You do not need to prepare resources in advance, and will not have excessive or insufficient preset resources. This mode applies if resource requirements fluctuate.
Table 1 lists the differences between the two billing modes.
| Billing Mode | Yearly/Monthly | Pay-per-Use |
| Payment | Prepaid | Postpaid |
| Billing Items |
| OS version changes: The number of changes for each instance at a time. Scenario-specific jobs: You can execute custom, public, or scheduled jobs. |
| Specification Change | All resources except O&M BI dashboard support specification change. | Not supported |
