- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Before You Start
- Permissions Management
Environment Management
- Environment Overview
- Creating an Environment
- Managing CCE Resources
- Managing Basic Resources
- Removing Managed Basic Resources
- Managing VM Agents
- Modifying an Environment
- Deleting an Environment
- Application Management
Component Management
- Component Overview
- Creating and Deploying a Component
- Viewing Component Details
- Managing Component Labels
- Changing the Component Description
- Managing Component Instances
- Upgrading a Single Component
- Upgrading Components in Batches
- Cloning Components in Batches
- Synchronizing Component Configurations in Batches
- Rolling Back a Component
- Redeploying a Component
- Configuring the Component Access Mode
- Changing the Component Access Domain Name
- Configuring a Scaling Policy of a Component Instance
- Component O&M
- Viewing the Component Running Environment
- Starting and Stopping a Component Instance
- Manually Synchronizing the Component Status
- Managing Cloud Service Settings of a Container-Deployed Component
- Managing Container Settings of a Container-Deployed Component
- Managing Application Settings of a Container-Deployed Component
- Managing Advanced Settings of a Container-Deployed Component
- Managing VM-Deployed Component Configurations
- Deleting a Component
- Configuration Management
- Release Management (OBT)
- Tech Stack Management
- Deployment Source Management
- Continuous Delivery
Microservice Engine
- Cloud Service Engine Overview
- Creating a Microservice Engine
Managing Microservice Engines
- Viewing Microservice Engine Information
- Obtaining the Service Center Address of a Microservice Engine
- Obtaining the Configuration Center Address of a Microservice Engine
- Viewing the Instance Quota of a Microservice Engine
- Viewing the Configuration Item Quota of a Microservice Engine
- Configuring Backup and Restoration of a Microservice Engine
- Managing Public Network Access for a Microservice Engine
- Viewing Microservice Engine Operation Logs
- Upgrading a Microservice Engine Version
- Deleting a Microservice Engine
- Managing Security Authentication for a Microservice Engine
- Using Microservice Engines
- Key Operations Recorded by CTS
- Viewing Monitoring Metrics and Alarms
Developer Guide
Microservice Developer Guide
- Overview
- Developing Microservice Applications
- Preparing the Environment
- Connecting Microservice Applications
- Deploying Microservice Applications
- Using Microservice Engine Functions
- Appendix
Best Practices
- ServiceStage Best Practices
- Hosting and Managing a Weather Forecast Microservice Application on ServiceStage
- Enabling Security Authentication for an Exclusive ServiceComb Engine
- Connecting ServiceComb Engine Dashboard Data to AOM through ServiceStage
- Migrating the Registered Microservice Engine Using ServiceStage Without Code Modification
- Hosting a Spring Boot Application on ServiceStage
- Using GitLab to Interconnect with Jenkins to Automatically Build and Upgrade Components Deployed on ServiceStage
- Using ServiceStage to Migrate Components Across AZs and Upgrade Components in Sequence Based on Release Management
API Reference
- Before You Start
- API Overview
- Calling APIs
Application Management V3 APIs
Environment
- Obtaining All Environments
- Deleting an Environment Based on the Environment ID
- Modifying an Environment Based on the Environment ID
- Obtaining Environment Details Based on the Environment ID
- Modifying an Environment Resource Based on the Environment ID
- Enabling an Environment Resource Based on the Environment ID
- Querying a Managed Resource Based on the Environment ID
- Querying a Created Resource Based on the Environment ID
- Adding an Environment Resource Based on the Environment ID
- Updating an Environment Resource Based on the Environment ID
- Deleting an Environment Resource Based on the Environment ID
- Querying Resource Enabling Records Based on the Environment ID
- Querying the Details of a Resource Enabling Record Based on the Environment ID
- Querying the Events of a Resource Enabling Record Based on the Environment ID
Application
- Creating an Application
- Obtaining All Applications
- Modifying Application Information Based on the Application ID
- Deleting an Application Based on the Application ID
- Obtaining Application Details Based on the Application ID
- Obtaining Application Configurations Based on the Application ID
- Modifying Application Configurations Based on the Application ID
- Deleting Application Configurations Based on the Application ID
Component
- Creating an Application Component
- Importing a CCE Workload to an Application to Create a Component
- Obtaining All Components of an Application
- Modifying Component Information Based on the Component ID
- Deleting a Component Based on the Component ID
- Obtaining Component Information Based on the Component ID
- Delivering a Component Task Based on the Component ID
- Obtaining Records Based on the Component ID
- Refreshing Component Information Based on the Component ID
- Obtaining Component Configuration Information
Technology Stack
- Querying a Runtime System Stack
- Querying a Built-in Image
- Creating a Technology Stack
- Querying a Technology Stack Based on the Technology Stack ID
- Modifying a Technology Stack Based on the Technology Stack ID
- Deleting a Technology Stack Based on the Technology Stack ID
- Releasing or Canceling the Release of a Technology Stack
- Creating a Configuration Group
- Obtaining a Configuration Group
- Creating a Configuration File
- Importing a Configuration File
- Obtaining Configuration File Information
- Obtaining Configuration File Information Based on the Configuration File ID
- Deleting a Configuration File Based on the Configuration File ID
- Modifying a Configuration File Based on the Configuration File ID
- Obtaining the Configuration File Record Based on the Configuration File ID
- Obtaining the Configuration File Record Information Based on the Record ID
- Deleting a Configuration File Record Based on the Record ID
- Obtaining Configuration Group Details Based on the Group ID
- Deleting a Configuration Group Based on the Group ID
- Deployment Job
- Add-on Management
Environment
Git Repository Access APIs
- Obtaining a Git Repository Authorization List
- Obtaining an Authorization Redirection URL
- Creating OAuth Authorization
- Creating Private Token Authorization
- Creating Password Authorization
- Deleting Repository Authorization
- Obtaining a Repository Namespace
- Obtaining Repository Information Based on the Clone URL
- Obtaining All Projects in a Namespace
- Creating a Software Repository Project
- Obtaining a Project Branch
- Obtaining a Project Tag
- Creating a Project Tag
- Deleting a Project Tag
- Obtaining Project Commits
- Obtaining a Project Hook
- Creating a Project Hook
- Deleting a Project Hook
- Obtaining a Repository File Directory
- Obtaining Repository File Contents
- Creating a Repository File
- Modifying Repository File Contents
- Deleting a Repository File
CSE APIs
- API Calling
- Dynamic Configuration
Engine Management
- Querying Flavors Supported by an Exclusive Microservice Engine
- Querying the Exclusive Microservice Engine List
- Creating an Exclusive Microservice Engine
- Querying Details About an Exclusive Microservice Engine
- Deleting an Exclusive Microservice Engine
- Querying Details About an Exclusive Microservice Engine Job
ServiceComb APIs
- API Calling
- Authentication
Microservice
- Querying Information About a Microservice
- Deleting Definition Information About a Microservice
- Querying Information About All Microservices
- Creating Static Information for a Microservice
- Deleting Static Information About Microservices in Batches
- Modifying Extended Attributes of a Microservice
- Querying the Unique Service or Schema ID of a Microservice
- Schema
Microservice Instance
- Registering a Microservice Instance
- Querying a Microservice Instance Based on service_id
- Deregistering a Microservice Instance
- Querying Details About a Microservice Instance
- Modifying the Extended Information About a Microservice Instance
- Modifying Status of a Microservice Instance
- Sending Heartbeat Information
- Querying a Microservice Instance by Filter Criteria
- Querying Microservice Instances in Batches
- Dependency
- Examples
- Data Structure
- Appendix
Historical APIs
Application Management V2 APIs
- Meta
- Environment
Application
- Component
- Instance
- Deployment Jobs
- Build APIs
- Querying Configurations
- Creating a Dependency Between Services
- Reporting Service Metrics
- SDK Reference
- Application Development FAQs
- Environment Management
- How Do I View the Causes of Application Component Deployment Failures?
- What If an Instance Is Being Created for a Long Time?
- How Do I Solve the Dependency Problem When a Node Program Runs in Docker?
- How Do I Customize a Tomcat Context Path?
- How Do I Use a Fixed Application Component IP?
- What Should I Do If an ECS Error Occurs When I Create and Deploy a Component on a VM?
- What Should I Do If I Cannot Access the Port When I Create and Deploy a Component on a VM?
- Which Directories Do I Use to Write Files for VM-Deployed Application Components?
- What Should I Do If "host status is not active" Is Reported When a VM-Deployed Component Fails to Be Deleted?
- How Do I Use the ServiceStage Source Code Deployment Function?
- What Should I Do If Components Fail to Be Upgraded in ServiceStage Dark Launch?
- How Do I Mount Items to Modify the Configuration File of a Container-based Component?
- What Should I Do If the Application Name Displayed on Microservice Governance Is Different from That Displayed on ServiceStage Application Management After an Application Component Is Connected to a Microservice Engine?
Continuous Delivery
- How Does ServiceStage Manage Code on IDEA?
- How Do I Add the Build Server Address to the GitLab Server Security Group?
- How Do I Add the Build Server Address to the Maven Server Security Group?
- What Do I Do If ServiceStage Failed to Build a Job?
- How Can I Access Dependent Services Through VPC Endpoints When Building Images?
- Software Center
Infrastructure
- Are Existing Programs Affected If I Unsubscribe Servers?
- How Can I Access Dependent Services Through VPC Endpoints When Installing VM Agents?
- What Should I Do If I Don't See the VM Agent After Installing It?
- What Should I Do If the VM Agent Is Offline?
- What Should I Do If the Service Registration Fails After IPv6 Is Enabled for the Exclusive Microservice Engine with Security Authentication Enabled?
- What Should I Do If a Non-Microservice Engine Error Occurs When I Operate an Exclusive Microservice Engine?
- How Do I Switch a Cluster Used for Component Building from a Shared Cluster to a Private One?
- What Should I Do If the Access Address Fails to Be Processed During CSE Creation?
- What Do I Need to Know Before Upgrading an Exclusive Microservice Engine?
- Obtain Configurations Failed
- Application O&M
- What Are the Differences Between the Microservice and Common Application?
- How Do I Handle a Microservice Registry Failure (Java Chassis)?
- How Do I Troubleshoot Microservices Deployed on the Cloud?
- Should I Use the SDK or ServiceMesh to Build a Microservice?
- What If I Fail to Obtain a Dependency?
- What Is Service Name Duplication Check?
- Why Do I Have to Define Service Contracts?
- Why Are Microservice Development Framework and Netty Versions Unmatched?
- How Do I Package a Java or Tomcat Application?
More Documents
- Getting Started
User Guide
- Overview
Application O&M
- Maintaining Application Component Instances
- Adding Labels for Application Component Instances
- Configuring Domain Name Mappings
- Configuring Alarm Thresholds for Resource Monitoring
- Configuring a Scaling Policy of an Application Component Instance
- Configuring a Scheduling Policy of an Application Component Instance
- Configuring an Upgrade Policy of an Application Component Instance
- Configuring Custom Monitoring of an Application Component
- Configuring a Log Policy of an Application
- Configuring Health Check
- Software Center
Infrastructure
Cloud Service Engine (CSE)
- Overview
Microservice Engine Management
- Configuring Backup and Restoration of an Exclusive Microservice Engine
- Configuring Public Network Access of an Exclusive Microservice Engine
- Viewing the Access Address of a Microservice Engine
- Viewing Operation Logs of an Exclusive Microservice Engine
- Upgrading an Exclusive Microservice Engine
- Using the Microservice Dashboard
- Microservice Governance
- Configuring Microservices
- Maintaining Microservices
- Installing VM Agent on a Single VM
- How Do I Obtain an AK/SK Pair?
- What Should I Do If an Error Occurs When I Change the Name of a Project ?
- What Are the Differences Between Microservices and Common Applications?
- How Do I View the Causes for Application Component Deployment Failures?
- What Should I Do If a VM Component Fails to Be Deployed or Updated?
- What Are the Constraints on Packaging a Node.js 8 Software Package?
- What Should I Do If the Agent Fails to Be Installed?
- What Should I Do If the Agent Is Offline?
- Which Directories Do I Use to Write Files for VM-based Application Components?
- What Should I Do If "host status is not active" Is Reported When a VM-based Component Fails to Be Deleted?
- How Do I Handle Docker Application Dependency?
- What Should I Do If Docker Client Fails to Push Images?
- How Do I Obtain a Project Name?
- What Should I Do I Get an ECS Error When Deploying VM-based Components?
- What Should I Do If an ECS Error Occurs During VM-based Component Deployment?
- What Should I Do If I Cannot Access the Port During VM-based Deployment?
- What Should I Do If the Microservice Application Name Is Different from the Component Application Name?
- Why the Microservice Name Is Different from the Component Name?
- Failed to Restore Data of an Exclusive Microservice Engine
- Before You Start
- API Overview
- Calling APIs
Application Management APIs
- Meta
- Environment
Application
- Adding or Modifying Application Configurations
- Component
Instance
- Creating an Application Component Instance
- Obtaining All Instances of a Component
- Querying the Operations Performed on a Component Instance
- Modifying an Application Component Instance
- Deleting an Application Component Instance
- Querying Instance Details Based on the Instance ID
- Obtaining Component Instance Snapshots
- Job
CSE API
- API Calling
- Querying Static Information About a Microservice
- Querying Static Information About All Microservices
- Modifying Static Information About a Microservice
- Querying a Microservice Schema
- Modifying a Microservice Schema
- Querying All Providers of a Microservice
- Querying All Instances of a Microservice Based on the Service ID
- Changing the Status of a Microservice Instance
- Deleting Static Information About a Microservice
- Querying All Schema Information About a Microservice
- Data Structure
- Appendix
- Getting Started
- Overview
- Setting the Access Mode of Components
- Component O&M
- Component Instance Start and Stop
Component Advanced Setting
- Setting Component Environment Variables
- Configuring the Lifecycle of a Component
- Configuring Data Storage
- Configuring a Distributed Cache
- Configuring Relational Databases
- Configuring a Scheduling Policy of a Component Instance
- Configuring Custom Monitoring of a Component
Microservice Engine
- Viewing the Quota of Microservice Engine Instances
- Viewing the Quota of Microservice Engine Configuration Items
- Managing Security Authentication of a Microservice Engine
- Infrastructure
- Application O&M
- Before You Start
- API Overview
- Calling APIs
- Meta
- Environment
Application
- Component
Instance
- Job
CSE API
- API Calling
- Data Structure
- Appendix
- Videos
Getting Started
Overview
This section describes the environments, applications, and components of ServiceStage.
- An environment is a combination of compute resources (such as CCE clusters), network resources (such as load balancers and EIPs), and middleware (such as DCS instances, RDS instances, and CSE engines). When deploying applications and components, you need to select an environment. After the environment is selected, the resources contained in the environment are automatically loaded.
- An application is a service system with functions and consists of one or more components. For example, a typical Enterprise Resource Planning (ERP) system is an application, which generally consists of modules such as accounting, finance, production control, logistics, procurement, distribution, and inventory. These modules are closely related to each other, and each module is a component.
- A component is an implementation of a service feature of an application, for example, a module of the preceding ERP system. In microservice application scenarios, each component has an independent software package and can be deployed and run independently. The deployed component is called a component instance. A component can have multiple component instances to form a cluster to ensure high reliability of applications and components. O&M operations are supported, such as starting, stopping, deploying (upgrading), rolling back, and scaling application component instances, viewing logs, viewing events, setting access modes, and setting threshold alarms.
This document describes how to set up an environment, create an application, create and deploy a component, confirm the deployment, access the application, and perform application O&M.
- Create a VPC. For details, see Creating a VPC.
- Create a CCE cluster. For details, see Creating a CCE Cluster.
The cluster must contain at least one ECS node with 8 vCPUs and 16 GB memory or two ECS nodes with 4 vCPUs and 8 GB memory and be bound to an EIP.
- Create a bucket for storing software packages. For details, see Creating a Bucket.
- For details about how to create a microservice engine with security authentication disabled, see Creating a Microservice Engine.
- This example provides a microservice demo, which is compiled, built, and packaged locally. You must install the Java JDK and Maven on the local host and the local host can access the Maven central library.
After the installation, open the Command Prompt, and run the mvn -v command to query the versions of Java JDK and Maven. If their versions are displayed, the installation is successful. In this example, Maven 3.6.3 and JDK 1.8.0 are used.
Apache Maven 3.6.3 (cecedd343002696d0abb50b32b541b8a6ba2883f) ... Java version: 1.8.0_201,......
Preparing Software Packages
- Download the microservice demo source code package to the local host and decompress it.
- In the root directory of the project (for example, D:\servicecomb-samples-master\servicecomb-samples-master\ServiceComb-SpringMVC), run the cmd and mvn clean package commands to compile and package the Java project.
D:\servicecomb-samples-master\servicecomb-samples-master\ServiceComb-SpringMVC>mvn clean package ...... [INFO] --- maven-jar-plugin:2.6:jar (default-jar) @ servicecomb --- [INFO] Building jar: D:\servicecomb-samples-master\servicecomb-samples-master\ServiceComb-SpringMVC\target\servicecomb-0.0.1-SNAPSHOT.jar [INFO] [INFO] --- spring-boot-maven-plugin:1.5.9.RELEASE:repackage (default) @ servicecomb --- [INFO] ------------------------------------------------------------------------ [INFO] BUILD SUCCESS ......
After compilation, the servicecomb-0.0.1-SNAPSHOT.jar software package is generated in the target subdirectory in the root directory of the project (for example, D:\servicecomb-samples-master\servicecomb-samples-master\ServiceComb-SpringMVC\target), and the message "BUILD SUCCESS" is displayed.
- Upload the generated servicecomb-0.0.1-SNAPSHOT.jar software package to the created OBS bucket.
For details about how to upload the software package, see Uploading a File.
Creating an Organization
- Log in to ServiceStage.
- Choose Deployment Source Management > Organization Management.
- Click Create Organization. On the displayed page, set Organization Name.
- Click OK.
- Choose Environment Management > Create Environment and set the environment information by referring to the following table.
Environment
Enter an environment name, for example, test-env.
* Enterprise Project
Enterprise project.
Enterprise projects let you manage cloud resources and users by project.
It is available after you create an enterprise project.
VPC
Select the VPC prepared in Prerequisites.
The VPC cannot be modified after the environment is created.
Environment Type
Select Kubernetes.
- Click Create Now.
- In the Resource Settings area, choose Cloud Container Engine from Compute and click Manage Resource.
- In the dialog box that is displayed, select the created CCE cluster and click OK.
- In the Resource Settings area, choose Cloud Service Engine from Middleware and click Manage Resource.
- In the dialog box that is displayed, select the created CSE engine and click OK.
- Choose Application Management > Create Application.
- Enter an application name, for example, test-servicestage. Select an enterprise project.
- Click OK.
- Choose Application Management. The application list is displayed.
- Select the application (for example, test-servicestage) created in Creating an Application and click Create Component in the Operation column.
- In the Basic Information area, set the following mandatory parameters. Retain the default values for other parameters.
Component Name
Enter a component name, for example, test-cse.
Environment
Select the environment created in Creating an Environment, for example, test-env.
- In the Component Package area, set the following mandatory parameters. Retain the default values for other parameters.
Stack
Select Java.
Upload Method
Click Software Package and select servicecomb-0.0.1-SNAPSHOT.jar uploaded in Preparing Software Packages.
- In the Build area, set the following mandatory parameters. Retain the default values for other parameters.
Organization
An organization is used to manage images generated during component build.
Select the organization created in Creating an Organization.
Environment
Select Use current environment to use the CCE cluster in the deployment environment to which the component belongs to build an image.
In the current environment, masters and nodes in the CCE cluster must have the same CPU architecture. Otherwise, the component build fails.
- Click Next.
- In the Resources area, retain the default settings.
- In the Access Mode area, retain the default settings.
- In the Local Time area, retain the default settings.
- In the Advanced Settings area, choose Advanced Settings > Microservice Engine.
- Click Bind Microservice Engine.
- Select the managed microservice engine in the current environment.
- Click OK.
- Click Create and Deploy to deploy the component.
Confirming the Deployment Result
- Choose Cloud Service Engine > Microservice Catalog.
- Select the microservice engine where the component is deployed from the microservice engine drop-down list.
- Select springmvc from the All applications drop-down list.
If the microservice servicecombspringmvc is displayed and the number of microservice instances is 2, the deployment is successful.
Accessing an Application
- Click the application created in Creating an Application (for example, test-servicestage). The Overview page is displayed.
- On the Component List tab, click the component created in Creating and Deploying a Component (for example, test-cse). The Overview page is displayed.
- Click Access Mode.
- Click Add Service in the TCP/UDP Route Configuration area and set parameters by referring to the following table.
Service Name
Retain the default value.
Access Mode
Select Public network access.
Access Type
Select Elastic IP address.
Service Affinity
Port Mapping
- Protocol: Select TCP.
- Container Port: Enter 8080.
- Access Port: Select Automatically generated.
- Click OK.
- Click the access address in the Access Address column to access the application.
The following information is displayed:
{"message":"Not Found"}
- Enter http://Access address generated in 7/rest/helloworld?name=ServiceStage in the address box of the browser to access the application again.
"ServiceStage"
Application O&M
- Click Application Management.
- On the Component List tab, click the component created in Creating and Deploying a Component (for example, test-cse). The Overview page is displayed, where you can perform O&M operations.
