Billing Mode
- Yearly/Monthly
Yearly/Monthly is a prepaid billing mode in which your subscription is billed based on the required duration. This mode is more cost-effective when the usage duration is predictable.
- Pay-per-use
Pay-per-use is a postpaid billing mode. You are billed for how long you use each ECS. You can purchase or delete such an ECS at any time.
- Differences Between Yearly/Monthly and Pay-per-Use
Table 1 Billing modes Billing Mode
Yearly/Monthly
Pay-per-use
Payment Mode
Prepaid
Billed by the purchase period specified in your order
Postpaid
Billed by usage duration
Billing Period
Billed for the required duration specified in your order.
Billed by the second. A bill is generated on the hour.
Billing Item
Compute resources
Compute resources and EVS disks
Applicable Resource Pool
Dedicated resource pools
Public resource pools and dedicated resource pools
Applicable Function
Standard ExeML, workflow, notebook, model training, and model deployment
Lite Cluster
Lite Server
Billing Mode Change
Not supported
The billing mode can be changed to yearly/monthly.
Flavor Change
N/A
Supported
This cost-effective mode is ideal when the duration of resource usage is predictable. This mode is recommended for long-term users.
This mode is suitable when you want more flexibility and control on compute resource usage.
Learn More
