Help Center/ Partner Center/ Drawer/ Setting Monthly Budgets for Customers
Updated on 2025-10-24 GMT+08:00
As a reseller, once your associated distributor grants you the budget setting permission and allocates you a monthly budget quota, you can set monthly budgets for your customers associated in the resale model, one by one or in a batch. The budgets will automatically restore at 00:00:00 on the first day of each month. Customers can spend according to the budgets obtained. We will send you an alert notification when a customer uses 75%, 90%, 100%, or more of the budget obtained. You can choose to adjust the budget for the customer or restrict their purchases.
  • Your distributor can grant a monthly budget quota and/or one-time budget quota to you.
  • If you do not have the permission to set a monthly budget for your customers, contact your associated distributor to set a monthly budget quota for you.
  • If you have permissions for setting monthly budgets and one-time budgets for your customers, you can change the budget type for the customers. The new budget type takes effect immediately.
  • You can set monthly budgets for your customers within the monthly budget quota granted by your distributor. You can view the monthly budget quota granted by your distributor in Partner Center > Partner Information > Basic Information > Budget Quota.
  1. Sign in to Huawei Cloud as a partner.
  2. In the drop-down list of your account name, click Partner Center to go to the Partner Center.
  3. In the top navigation bar, choose Sales > Customers > Customer Management.
  4. In the customer list, select a customer and click Set Budget in the Operation column, or click Set Budget above the list to go to the Set Budget page. On the displayed page, set Budget Type to Monthly Budget.
  5. Enter a value for Monthly Budget, select an action in the Action Upon Budget Exhaustion area, and click OK.
    • Manual freezing
    • Restricting purchases
    • Restricting purchases and freezing resources
    • If you select Restrict Purchase and Freeze Resources for Action Upon Budget Exhaustion, you have to read and agree to the Agreement for Partners to Manage Customer Budgets before clicking OK.
    • If purchases are restricted for a customer account. To enable purchases for this account, increase the budget and unrestrict purchases for this account. Select Synchronously unrestrict purchases and click OK.
    • If a customer account is restricted from purchases and the resources are frozen, you can increase the budget, unrestrict the purchases, and unfreeze the resources to enable purchases for this account. Select Synchronously unrestrict purchases and unfreeze resources and click OK.
    • After a customer is associated with you in the Reseller model, the customer account is restricted from purchases by default. You can click Unrestrict Purchase in the Operation column, or select Synchronously unrestrict purchases when setting the budget to remove the restriction.
    • If the action upon budget exhaustion is changed to Restrict Purchase or Restrict Purchase and Freeze Resources, Partner Center will send an SMS or email to verify the operator's identity. This enhances account safety and allows secure access to relevant features.
    • You can view adjustment records of monthly budgets by clicking Adjustment Records.
    • Click the eye button next to Customer Name to show or hide the complete content of customer name.
    • The budget type can be changed. The new budget type will take effect immediately. After you have changed the budget type from one-time budget to monthly budget for a customer, pay attention to the current estimate (the data is an estimate and may be delayed by about 10 minutes). In this case, the current estimate is equal to the month-to-date expenditure. When you change the budget type from monthly budget to one-time budget for a customer, the accumulated expenditure is calculated only from the month when the budget type is changed.
    • Having no budget will not prevent the customer from purchasing pay-per-use resources, and the provisioned pay-per-use resources still incur fees. To avoid incurring additional charges for resources, restrict purchases and freeze the resources. For details, see Restricting Purchases and Freezing Resources.
    • If you have enabled the verification code function, a verification code will be required. For details about how to enable verification code function, see Managing Basic Information.
  6. Click OK.
Actions Upon Budget Exhaustion
Huawei Cloud bears no liability whatsoever for any adverse effects on customer services or any disputes arising from the implementation of the action you configured for budget exhaustion. Exercise caution when configuring the actions.
Action
Impact
Follow-up Operations
Manual Freezing
  • Yearly/monthly resources cannot be purchased, renewed, or changed.
  • Yearly/monthly resources that have already been purchased can still be used.
  • Pay-per-use resources can be purchased.
  • Pay-per-use resources that have already been purchased can be used, but they still incur fees.
After receiving an alert notification, take corresponding measures as needed:
  • Increase the customer budget to clear the alert.
  • Manually restrict purchases of pay-per-use resources (the resources already purchased still incur fees). For details, see Restricting Purchases.
  • Manually restrict purchases and freeze resources. Prepaid resources, such as yearly/monthly resources, that have already been purchased can still be used, and pay-per-use resources that have already been purchased will not incur new fees. For details, see Restricting Purchases and Freezing Resources.
Restrict Purchase
  • Pay-per-use resources cannot be purchased.
After a customer account is restricted from purchasing resources, take corresponding measures as needed:
  • Increase the budget and unrestrict the purchases.
  • Unrestrict purchases. For details, see Unrestricting Purchases.
Restrict Purchase and Freeze Resources (which may interrupt customer services)
  • Pay-per-use resources that have already been purchased cannot be used and will enter a retention period. After the retention period ends, the stored data will be deleted and the cloud service resources will be released. Reserved instances and savings plans that were not fully pre-paid will be unsubscribed from.
After a customer account is restricted from purchases and the resources are frozen, take corresponding measures as needed:
