Scaling Based on Prometheus Metrics
Kubernetes' default HPA policy only allows for auto scaling based on CPU and memory usage. However, in more complex service scenarios, this may not be sufficient to meet routine O&M requirements. To address this, CCE offers a Cloud Native Cluster Monitoring (kube-prometheus-stack) add-on that integrates into the open-source Prometheus ecosystem. This add-on allows for monitoring of various components and provides multiple preset monitoring dashboards that are ready to use out-of-the-box. This section describes how to convert Huawei Cloud Prometheus metrics into metrics that can be used by an HPA, providing a more convenient scaling approach for applications.
- A cluster is available.
- You can access the cluster using kubectl. For details, see Accessing a Cluster Using kubectl.
Step 1: Install Cloud Native Cluster Monitoring
- Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons.
- Locate the Cloud Native Cluster Monitoring add-on and click Install. Prioritize the configurations listed below and adjust any other configurations as needed. For details, see Cloud Native Cluster Monitoring.
- Local Data Storage: Enable this option to store the monitoring data in local storage. You can determine whether to report the monitoring data to AOM or a third-party monitoring platform.
- Custom Metric Collection: Enable this option in this practice. If this option is not enabled, custom metrics cannot be collected.
- Click Install.
Step 2: Obtain Prometheus Monitoring Data
In this section, HPA scaling is performed based on metrics related to pods, for example, pod metrics. You can also perform HPA scaling based on metrics unrelated to pods, for example, external load balancer metrics. For details, see Scaling Based on Load Balancer Monitoring Metrics.
The following describes how to deploy a sample-app application and expose the container_memory_working_set_bytes_per_second metric in Prometheus standard mode to identify the number of bytes per second in the working set of the container memory. For details about Prometheus metrics, see Metric types.
- Deploy a test application.
- Write a sample-app.yaml file. The file content is as follows:
apiVersion: apps/v1 kind: Deployment metadata: name: sample-app labels: app: sample-app spec: replicas: 1 selector: matchLabels: app: sample-app template: metadata: labels: app: sample-app spec: containers: - image: swr.cn-east-3.myhuaweicloud.com/container/autoscale-demo:v0.1.2 # Sample image name: metrics-provider resources: requests: cpu: 250m memory: 512Mi limits: cpu: 250m memory: 512Mi ports: - name: http containerPort: 8080 #Container port imagePullSecrets: - name: default-secret --- apiVersion: v1 kind: Service metadata: name: sample-app namespace: default labels: app: sample-app spec: ports: - port: 80 name: http protocol: TCP targetPort: 8080 selector: app: sample-app type: ClusterIP
The application exposes container_memory_working_set_bytes_per_second to check the working memory size of a container per second.
- Create the workload.
kubectl apply -f sample-app.yaml
- Create a ServiceMonitor to monitor custom metrics.
- Create a servicemonitor.yaml file. The file content is as follows:
apiVersion: monitoring.coreos.com/v1 kind: ServiceMonitor metadata: name: sample-app # ServiceMonitor name namespace: default spec: endpoints: # Endpoints of the service to be monitored, including the name, port number, path, protocol, and more - interval: 30s # Prometheus operator checks whether a service needs to be added to the monitored target list every 30 seconds. port: http path: /metrics namespaceSelector: any: true selector: matchLabels: app: sample-app # Label of the object whose data needs to be collected - Create the ServiceMonitor.
kubectl apply -f servicemonitor.yaml
Step 3: Modify Configuration Files
- Modify Prometheus' adapter-config.
You can modify the rules field in adapter-config to convert the metrics exposed by Prometheus to metrics that can be associated with the HPA.
kubectl -n monitoring edit configmap user-adapter-config
- Add a custom metric collection rule to the rules field. You can add multiple collection rules by adding multiple configurations under the rules field. For details, see Metrics Discovery and Presentation Configuration. The following is an example of a custom collection rule:
rules: - seriesQuery: container_memory_working_set_bytes{namespace!="",pod!=""} resources: overrides: namespace: resource: namespace pod: resource: pod name: matches: ^(.*)_bytes as: ${1}_bytes_per_second #The value of ${1} is the value that matches ^(.*) in matches:"^(.*)_bytes". metricsQuery: sum(<<.Series>>{<<.LabelMatchers>>}) by (<<.GroupBy>>)- seriesQuery: indicates the PromQL request data. It specifies the metrics to be obtained by users. You can configure this parameter as needed.
- metricsQuery: aggregates the data requested by PromQL in seriesQuery.
- resources: specifies data label in PromQL, which is used to match resources. The resources here refer to the api-resource in a cluster, such as pods, namespaces, and nodes. You can run kubectl api-resources -o wide to check the resources. The key corresponds to LabelName in the Prometheus data. You have to ensure that the Prometheus metric data contains LabelName.
- name: indicates that Prometheus metric names are converted to readable metric names based on regular expression matching. In this example, container_memory_working_set_bytes is converted to container_memory_working_set_bytes_per_second.
- Redeploy the custom-metrics-apiserver workload in the monitoring namespace.
kubectl -nmonitoring delete pod -l app=custom-metrics-apiserver
- Check whether the metric has been added.
kubectl get --raw /apis/custom.metrics.k8s.io/v1beta1/namespaces/default/pods/*/container_memory_working_set_bytes_per_second
Step 4: Create an HPA Policy
- Create an HPA policy using custom metrics.
- Create an hpa.yaml file. The file content is as follows:
kind: HorizontalPodAutoscaler apiVersion: autoscaling/v2 metadata: name: sample-app-memory-high spec: # Description of an HPA target. The HPA dynamically changes the number of pods of the target. scaleTargetRef: apiVersion: apps/v1 kind: Deployment name: sample-app # Minimum number of pods and maximum number of pods of the HPA minReplicas: 1 maxReplicas: 10 #Monitored metric array. Multiple types of metrics can coexist. metrics: - type: Pods pods: metric: name: container_memory_working_set_bytes_per_second # Use the custom container metrics. target: type: AverageValue # Target value of the AverageValue type. For the pod metrics, only the target values of the AverageValue type are supported. averageValue: 1024000m # 1024000m specifies 1 KB. - Create the HPA policy.
kubectl apply -f hpa.yaml
- Check whether the HPA policy takes effect.
kubectl get hpa sample-app-memory-high
The number of replicas has been increased from 1 to 10.
