Updating Resources Accordingly
Updating Images
The WordPress and MySQL images used in this example can be pulled from SWR. Therefore, the image pull failure (ErrImagePull) will not occur. If the application to be migrated is created from a private image, perform the following operations to update the image:
- Migrate the images to SWR. For details, see Pushing an Image.
- Log in to the SWR console and obtain the image address after the migration. The image address is in the following format:
'swr.{Region}.myhuaweicloud.com/{Organization name}/{Image name}:{Tag name}' - Run the following command to modify the workload and replace the image field in the YAML file with the image address:
kubectl edit deploy wordpress
- Check the workload status.
Updating Services
After the cluster is migrated, the Services in the source cluster may not work. You can perform the following operations to update the Service. If there are ingresses in the source cluster, you must re-associate them with load balancers after the migration. For details, see Creating a LoadBalancer Ingress Using kubectl.
- Access the cluster using kubectl.
- Edit the YAML file of the corresponding Service to change the Service type and port number.
kubectl edit svc wordpress
After updating a LoadBalancer Service, re-associate it with the load balancer. Add the annotations by following the procedure in Using kubectl to Create a Service (Using an Existing Load Balancer).annotations: kubernetes.io/elb.class: union # Shared load balancer kubernetes.io/elb.id: 9d06a39d-xxxx-xxxx-xxxx-c204397498a3 # Load balancer ID, which can be queried on the ELB console. kubernetes.io/elb.session-affinity-mode: SOURCE_IP # Enable the sticky session based on the source IP address.
- Use a browser to check whether the Service is available.
Updating Storage Classes
As the storage infrastructures of clusters may be different, storage volumes cannot be mounted to the target cluster. You can use either of the following methods to update the volumes:
Both update methods can be performed only before applications are restored to the target cluster. Otherwise, PV data may fail to restore. In this case, use Velero to restore applications after the storage class update is complete. For details, see Restoring the Application to the Target Cluster.
Method 1: Creating a ConfigMap mapping
- Create a ConfigMap in the CCE cluster and map the storage classes used by the source cluster to the default storage classes of the CCE cluster.
apiVersion: v1 kind: ConfigMap metadata: name: change-storageclass-plugin-config namespace: velero labels: app.kubernetes.io/name: velero velero.io/plugin-config: "true" velero.io/change-storage-class: RestoreItemAction data: {Storage class name01 in the source cluster}: {Storage class name01 in the target cluster} {Storage class name02 in the source cluster}: {Storage class name02 in the target cluster} - Apply the ConfigMap settings.
kubectl create -f change-storage-class.yaml configmap/change-storageclass-plugin-config created
Method 2: Creating storage classes with the same name
- Obtain the default storage classes supported by CCE.
kubectl get sc
Information similar to the following is displayed:csi-disk everest-csi-provisioner Delete Immediate true 77d csi-disk-dss everest-csi-provisioner Delete Immediate true 77d csi-disk-topology everest-csi-provisioner Delete WaitForFirstConsumer true 77d csi-local everest-csi-provisioner Delete Immediate false 19d csi-local-topology everest-csi-provisioner Delete WaitForFirstConsumer true 19d csi-nas everest-csi-provisioner Delete Immediate true 77d csi-obs everest-csi-provisioner Delete Immediate false 77d csi-sfs everest-csi-provisioner Delete Immediate false 77d csi-sfsturbo everest-csi-provisioner Delete Immediate true 77d
Table 1 Storage classes Storage Class
Storage Resource
csi-disk
EVS disk
csi-disk-topology
EVS disk with delayed binding
csi-disk-dss
DSS disk
csi-local
Local PV
csi-local-topology
Local PV with delayed binding
csi-nas
File system (SFS 1.0)
csi-sfs
General purpose file system (SFS 3.0 Capacity-Oriented)
csi-obs
OBS bucket
csi-sfsturbo
SFS Turbo file system
- Export the required storage class details in the YAML format.
kubectl get sc <storageclass-name> -o=yaml
- Copy the YAML file and create new storage classes.
Change the storage class names to the names used in the source cluster to call basic storage resources on the cloud.
The YAML file of csi-obs is used as an example. Delete unnecessary information, such as creationTimestamp, resourceVersion, selfLink, and uid, under the metadata field and change the name field. You are advised not to modify other parameters.apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: creationTimestamp: "2021-10-18T06:41:36Z" name: <your_storageclass_name> # Use the name of the storage class used in the source cluster. resourceVersion: "747" selfLink: /apis/storage.k8s.io/v1/storageclasses/csi-obs uid: 4dbbe557-ddd1-4ce8-bb7b-7fa15459aac7 parameters: csi.storage.k8s.io/csi-driver-name: obs.csi.everest.io csi.storage.k8s.io/fstype: s3fs everest.io/obs-volume-type: STANDARD provisioner: everest-csi-provisioner reclaimPolicy: Delete volumeBindingMode: Immediate
- CCE does not support EVS disks of the ReadWriteMany type. If resources of this type exist in the source cluster, change the storage type to ReadWriteOnce.
- Restore the cluster application by referring to Restoring the Application to the Target Cluster and check whether the PVC has been created.
kubectl get pvc
In the command output, the VOLUME column indicates the name of the PV automatically created using the storage class.NAME STATUS VOLUME CAPACITY ACCESS MODES STORAGECLASS AGE pvc Bound pvc-4c8e655a-1dbc-4897-ae6c-446b502f5e77 5Gi RWX local 13s
Updating Databases
A local MySQL database is used as an example. It does not need to be reconfigured after the migration. If you use DRS to migrate a local database to RDS, configure database access based on site requirements after the migration.
- If the RDS instance is in the same VPC as the CCE cluster, it can be accessed using the private IP address. If it is not, it can only be accessed through the Internet with an EIP. You are advised to use the private network access mode for high security and good RDS performance.
- Traffic from the cluster has been allowed in the inbound rule of the RDS security group. Otherwise, the access will fail.
- Log in to the RDS console and obtain the private IP address and port number of the DB instance on the Summary page.
- Modify the WordPress workload.
Configure the environment variables in the env field.
- WORDPRESS_DB_HOST: address and port number used for accessing the database, that is, the internal network address and port number obtained in the previous step
- WORDPRESS_DB_USER: username for accessing the database
- WORDPRESS_DB_PASSWORD: password for accessing the database
- WORDPRESS_DB_NAME: name of the database to be connected
- Check whether the RDS database is properly connected.
