Help Center/ Cloud Container Engine/ Best Practices/ Batch Computing/ Deploying and Using ClickHouse in a CCE Cluster
Updated on 2026-09-08 GMT+08:00
ClickHouse is a columnar database management system for online analytical processing (OLAP). It is suitable for real-time query and analysis of large-scale datasets. There are four ways to deploy ClickHouse in containers. For details, see Table 1. ClickHouse Operator is a tool for deploying and managing ClickHouse in Kubernetes clusters. It can replicate clusters and manage users, configuration files, and persistent volumes. These functions simplify application configuration, management, and monitoring.
Table 1 Deploying ClickHouse in containers
Deployment Method
Difficulty in Deployment
Difficulty in Management
Native kubectl
Difficult
Difficult
kubectl and Operator
Medium
Medium
Helm
Easy
Difficult
Helm and Operator
Easy
Easy
This section describes how to deploy ClickHouse in a CCE cluster using kubectl and Operator. For details, see https://github.com/Altinity/clickhouse-operator.
The following describes how to deploy ClickHouse in a CCE Turbo cluster of v1.29. For details about the cluster parameters, see Table 2.
Table 2 Cluster parameters
Value
Type
CCE Turbo Cluster
Cluster Version
1.29
Region
AP-Singapore
Container Runtime
containerd
Network Model
Cloud Native Network 2.0
Request Forwarding
iptables
  1. Create a ClickHouse Operator.
    1. Download the YAML file clickhouse-operator-install-bundle.yaml from https://github.com/Altinity/clickhouse-operator/blob/master/deploy/operator/clickhouse-operator-install-bundle.yaml.
      clickhouse-operator-install-bundle.yaml is used to deploy the ClickHouse Operator in the kube-system namespace to monitor the resources in all Kubernetes namespaces. If the ClickHouse Operator is deployed in another namespace, only resources in that namespace are monitored.
      kubectl apply -f clickhouse-operator-install-bundle.yaml
      Information similar to the following is displayed:
      customresourcedefinition.apiextensions.k8s.io/clickhouseinstallations.clickhouse.altinity.comcreated
      customresourcedefinition.apiextensions.k8s.io/clickhouseinstallationtemplates.clickhouse.altinity.com created
      customresourcedefinition.apiextensions.k8s.io/clickhouseoperatorconfigurations.clickhouse.altinity.com created
    2. Check whether the ClickHouse Operator has been created.
      kubectl get pod -n kube-system | grep clickhouse
      If the pod status is Running, the ClickHouse Operator has been created.
      clickhouse-operator-656d67bd4d-k64gm          2/2      Running    4 (15m ago)    3d23h
    3. Check all CRDs related to ClickHouse in the cluster.
      kubectl get crd | grep clickhouse
      clickhouseinstallations.clickhouse.altinity.com                2024-08-20T09:30:30Z
      clickhouseinstallationtemplates.clickhouse.altinity.com        2024-08-20T09:30:30Z
      clickhousekeeperinstallations.clickhouse-keeper.altinity.com   2024-08-20T09:30:30Z
      clickhouseoperatorconfigurations.clickhouse.altinity.com       2024-08-20T09:30:30Z
  2. Create a test-clickhouse-operator namespace. To facilitate the verification, the subsequent operations are all performed in test-clickhouse-operator.
    kubectl create namespace test-clickhouse-operator
  3. Create a ClickHouse cluster.
    1. Create a YAML file named simple-01.yaml. You can obtain simple-01.yaml from https://raw.githubusercontent.com/Altinity/clickhouse-operator/master/docs/chi-examples/01-simple-layout-01-1shard-1repl.yaml.
      vim simple-01.yaml
      ClickHouseInstallation is a CR defined when a ClickHouse Operator is used in a Kubernetes cluster. After ClickHouseInstallation resources are created or updated, the ClickHouse Operator automatically creates and manages Kubernetes resources, such as StatefulSets, Services, and PVCs, to ensure that the ClickHouse cluster runs as expected.
      The file content is as follows:
      apiVersion: "clickhouse.altinity.com/v1"
      kind: "ClickHouseInstallation"
        configuration:
          users:
            # printf 'test_password' | sha256sum
            test_user/password_sha256_hex: 10a6e6cc8311a3e2bcc09bf6c199adecd5dd59408c343e926b129c4914f3cb01
            test_user/password: test_password
            # to allow access outside from kubernetes
            test_user/networks/ip:
            - 0.0.0.0/0
          clusters:
          - name: "simple"
      Create the ClickHouse cluster.
      kubectl apply -n test-clickhouse-operator -f simple-01.yaml
  4. Check whether ClickHouse resources have been created.
    1. Check the pods in the test-clickhouse-operator namespace. If all pods are in the Running state, the pods have been created.
      kubectl get pod -n test-clickhouse-operator
      NAME                               READY   STATUS    RESTARTS      AGE
      chi-simple-01-simple-0-0-0         2/2     Running   0             3d7h
    2. Check other service resources.
      kubectl get service -n test-clickhouse-operator
      NAME                         TYPE        CLUSTER-IP    EXTERNAL-IP   PORT(S)                      AGE
      chi-simple-01-simple-0-0     ClusterIP   None          <none>        9000/TCP,8123/TCP,9009/TCP   3d7h
      clickhouse-simple-01         ClusterIP   None          <none>        9000/TCP,8123/TCP            3d8h
  5. Access the ClickHouse database.
    kubectl -n test-clickhouse-operator exec -ti chi-simple-01-simple-0-0-0 -- clickhouse-client
    If information similar to that shown below is displayed, the connection is successful. Enter exit and press Enter to exit the ClickHouse database.
    ClickHouse client version 24.8.2.3 (official build).
    Connecting to localhost:9000 as user default.
    Connected to ClickHouse server version 24.8.2.
    Warnings:
     * Linux transparent hugepages are set to "always". Check /sys/kernel/mm/transparent_hugepage/enabled
    chi-simple-01-simple-0-0-0.chi-simple-01-simple-0-0.test-clickhouse-operator.svc.cluster.local :)
  6. Clear the ClickHouse cluster resources.
    Delete the ClickHouse cluster.
    kubectl delete -f simple-01.yaml -n test-clickhouse-operator
    clickhouseinstallation.clickhouse.altinity.com "simple-01" deleted
Example 1: Creating a ClickHouse Cluster with a PV Provisioned Dynamically
The following example describes how to create a ClickHouse cluster with a PV dynamically provisioned. An EVS volume is used as an example to describe how to dynamically provision a PV for a ClickHouse cluster.
VolumeClaimTemplate can only be used to provision EVS disks and local PVs for StatefulSets.
  1. Create a storage class.
    1. Create a YAML file named csi-disk-ssd.yaml.
      vim csi-disk-ssd.yaml
      By default, CCE supports SAS disks. If you want to use another type of disk, you need to create the corresponding storage class. For details about storage class parameters, see Table 3.
      allowVolumeExpansion: true
      apiVersion: storage.k8s.io/v1
      kind: StorageClass
      provisioner: everest-csi-provisioner
      parameters:
        csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io
        csi.storage.k8s.io/fstype: ext4
        everest.io/disk-volume-type: SSD
        everest.io/passthrough: "true"
      reclaimPolicy: Delete
      volumeBindingMode: Immediate
      Table 3 Storage class parameters
      provisioner
      Specifies the storage resource provider, which is the CCE Container Storage (Everest) add-on. Set this parameter to everest-csi-provisioner.
      parameters
      Specifies the storage parameters, which vary with storage types.
      NOTICE:
      everest.io/disk-volume-type indicates the cloud disk type, which can be any of the following:
      • SAS: high I/O
      • SSD: ultra-high I/O
      • GPSSD: general purpose SSD
      • ESSD: extreme SSD
      • GPSSD2: general purpose SSD v2, which is supported when the CCE Container Storage (Everest) version is 2.4.4 or later and the everest.io/disk-iops and everest.io/disk-throughput annotations are configured.
      • ESSD2: extreme SSD v2, which is supported when the CCE Container Storage (Everest) version is 2.4.4 or later and the everest.io/disk-iops annotation is configured.
      Default: SAS
      reclaimPolicy
      Specifies the value of persistentVolumeReclaimPolicy for creating a PV. The value can be Delete or Retain. If reclaimPolicy is not specified when a storage class object is created, the value defaults to Delete.
      • Delete: indicates that a dynamically provisioned PV will be automatically deleted when the PVC is deleted.
      • Retain: indicates that a dynamically provisioned PV will be retained when the PVC is deleted.
      volumeBindingMode
      Specifies when a PV is dynamically provisioned. The value can be Immediate or WaitForFirstConsumer.
      • Immediate: The PV is dynamically provisioned when a PVC is created.
      • WaitForFirstConsumer: The PV is dynamically provisioned when the PVC is used by the workload.
    2. Use csi-disk-ssd.yaml to create a storage class named csi-disk-ssd.
      kubectl create -f csi-disk-ssd.yaml
  2. Create a ClickHouse cluster with a PV dynamically provisioned.
    1. Create a YAML file named pv-simple.yaml.
      vim pv-simple.yaml
      For details about the file content, see https://github.com/Altinity/clickhouse-operator/blob/master/docs/chi-examples/03-persistent-volume-01-default-volume.yaml.
      EVS volumes can be mounted as read-write to a single node, so accessModes must be set to ReadWriteOnce.
        namespace: test-clickhouse-operator
        defaults:
          templates:
            dataVolumeClaimTemplate: data-volume-template
            logVolumeClaimTemplate: log-volume-template
        configuration:
          clusters:
            - name: "simple"
              layout:
                shardsCount: 1
                replicasCount: 1
        templates:
          volumeClaimTemplates:                   # Dynamic provisioning
            - name: data-volume-template          # Template for defining a data storage volume
                accessModes:
                  - ReadWriteOnce                 # EVS disks can be mounted as read-write by a single node, so accessModes must be set to ReadWriteOnce.
                resources:
                  requests:
                    storage: 10Gi
                storageClassName: csi-disk-ssd    # Specify the newly created csi-disk-ssd as the storage class.
            - name: log-volume-template           # Template for defining the log storage volume
                accessModes:
                resources:
                  requests:
                    storage: 10Gi
    2. Create the ClickHouse cluster.
      kubectl -n test-clickhouse-operator create -f pv-simple.yaml
  3. Check whether the ClickHouse cluster has been created and whether the PV has been provisioned.
      If information similar to the following is displayed, the pods have been created:
      chi-pv-simple-simple-0-0-0      2/2     Running   0          5m2s
      chi-simple-01-simple-0-0-0      1/1     Running   0          3d7h
    2. Check whether the PVCs named data-volume-template and log-volume-template have been created.
      kubectl get pvc -n test-clickhouse-operator
      If STATUS is Bound, the PVCs have been bound to the PVs.
      NAME                                              STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS   VOLUMEATTRIBUTESCLASS   AGE
      data-volume-template-chi-pv-simple-simple-0-0-0   Bound    pvc-981b1d73-a13e-41d5-aade-ea8c6b1199d7   10Gi       RWO            csi-disk-ssd   <unset>                 28s
      log-volume-template-chi-pv-simple-simple-0-0-0    Bound    pvc-fcf70a2e-131d-4da1-a9c2-eddd89887b45   10Gi       RWO            csi-disk-ssd   <unset>                 28s
    3. Check whether the PV has been mounted to the cluster.
      Go to the CLI of the chi-pv-simple-simple-0-0-0 container.
      kubectl -n test-clickhouse-operator exec -ti chi-pv-simple-simple-0-0-0 -c clickhouse bash
      Check whether the PV has been mounted to the container.
      df -h
      The command output shows that the PV has been mounted to the container. You can press Ctrl+D to exit the CLI.
      Filesystem                    Size    Used   Avail  Use% Mounted on
      overlay                        99G    5.1G     89G    6% /
      tmpfs                          64M       0     64M    0% /dev
      tmpfs                          3.9G      0    3.9G    0% /sys/fs/cgroup
      /dev/mapper/vgpaas-share       99G    5.1G     89G    6% /etc/hosts
      shm                            64M       0     64M    0% /dev/shm
      /dev/sdb                       9.8G    66M    9.8G    1% /var/lib/clickhouse
      /dev/sda                       9.8G    37M    9.8G    1% /var/log/clickhouse-server
      tmpfs                          6.3G     12K    6.3G   1% /run/secrets/kubernetes.io/serviceaccount
      tmpfs                          3.9G       0    3.9G   0% /proc/acpi
      tmpfs                          3.9G       0    3.9G   0% /proc/scsi
      tmpfs                          3.9G       0    3.9G   0% /sys/firmware
  4. Access the ClickHouse database.
    kubectl -n test-clickhouse-operator exec -ti chi-pv-simple-simple-0-0-0 -- clickhouse-client
    If information similar to that shown below is displayed, you have accessed the ClickHouse database. Enter exit and press Enter to exit the ClickHouse database.
    Defaulted container "clickhouse" out of: clickhouse, clickhouse-log
    Warnings:
    chi-pv-simple-simple-0-0-0.chi-pv-simple-simple-0-0.test-clickhouse-operator.svc.cluster.local :)
  5. Clear the ClickHouse cluster resources.
    Delete the ClickHouse cluster with a PV provisioned dynamically.
    kubectl delete -f pv-simple.yaml -n test-clickhouse-operator
    clickhouseinstallation.clickhouse.altinity.com "pv-simple" deleted
Example 2: Creating a ClickHouse Cluster with a LoadBalancer Service
The following example describes how to create a ClickHouse cluster with a LoadBalancer Service. The LoadBalancer Service allows you to access the ClickHouse cluster from the Internet.
  1. Create a ClickHouse cluster with a LoadBalancer Service so that you can access the ClickHouse cluster from the Internet.
    1. Create a YAML file named elb.yaml.
      vim elb.yaml
      For details about parameters in kubernetes.io/elb.autocreate, see Table 4.
        defaults:
          templates:
            dataVolumeClaimTemplate: data-volume-nas
            serviceTemplate: chi-service-elb
        configuration:
          clusters:
            - name: "ck-elb"
              templates:
                podTemplate: pod-template-with-nas
              layout:
                shardsCount: 1
                replicasCount: 1
        templates:
          podTemplates:
            - name: pod-template-with-nas
                containers:
                  - name: clickhouse
                    image: clickhouse/clickhouse-server:23.8
                    volumeMounts:
                      - name: data-volume-nas
                        mountPath: /var/lib/clickhouse
          volumeClaimTemplates:               # Specify the storage access mode, requested storage size, and storage class.
                accessModes:
                  - ReadWriteOnce
                resources:
                  requests:
                    storage: 20Gi
          serviceTemplates:                  # Service template
            - name: chi-service-elb
                annotations:
                  # Load balancer type. union (default value) indicates shared load balancers, and performance indicates dedicated load balancers.
                  kubernetes.io/elb.class: union
                  # Automatically create a load balancer associated with the ingress and define load balancer parameters.
                  kubernetes.io/elb.autocreate: >-
                    {"type":"public","bandwidth_name":"cce-bandwidth-ck","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp"}
                ports:
                  - name: http
                    port: 8123
                  - name: client
                    port: 9000
                type: LoadBalancer             # Set the Service type to LoadBalancer.
      Table 4 Parameters in the kubernetes.io/elb.autocreate file
      Mandatory
      Type
      type
      No
      String
      Network type of the load balancer.
      • public: public network load balancer
      • inner: private network load balancer
      Default: inner
      bandwidth_name
      Yes for public network load balancers
      String
      Bandwidth name. The default value is cce-bandwidth-******.
      The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
      No
      String
      Bandwidth billing mode.
      • bandwidth: billed by bandwidth
      • traffic: billed by traffic
      Default: bandwidth
      bandwidth_size
      Integer
      Bandwidth size. The default value is 1 to 2,000 Mbit/s. Configure this parameter based on the bandwidth range allowed in your region.
      The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
      • If the allowed bandwidth does not exceed 300 Mbit/s, the minimum increment is 1 Mbit/s.
      • If the allowed bandwidth is greater than 300 Mbit/s but less than or equal to 1,000 Mbit/s, the minimum increment is 50 Mbit/s.
      • If the allowed bandwidth exceeds 1,000 Mbit/s, the minimum increment is 500 Mbit/s.
      bandwidth_sharetype
      String
      The bandwidth sharing mode. PER indicates that the bandwidth is dedicated.
      eip_type
      String
      EIP type.
      • 5_bgp: Dynamic BGP
      • 5_sbgp: Static BGP
      The types vary by region. For details, see the EIP console.
      kubectl create -f elb.yaml -n test-clickhouse-operator
  2. Check whether the ClickHouse cluster has been created and has a LoadBalancer Service in it.
      If information similar to the following information is displayed, the ClickHouse cluster has been created:
      chi-ck-elb-ck-elb-0-0-0         1/1     Running   0          3m4s
      chi-pv-simple-simple-0-0-0      2/2     Running   0          33m
    2. Check whether the LoadBalancer Service has been created.
      kubectl get svc -n test-clickhouse-operator
      If information similar to the following is displayed, the LoadBalancer Service has been created:
      chi-ck-elb-ck-elb-0-0         ClusterIP     None           <none>         9000/TCP,8123/TCP,9009/TCP       2s
      chi-pv-simple-simple-0-0      ClusterIP     None           <none>         9000/TCP,8123/TCP,9009/TCP       35m
      chi-simple-01-simple-0-0      ClusterIP     None           <none>         9000/TCP,8123/TCP,9009/TCP       38m
      clickhouse-pv-simple          ClusterIP     None           <none>         8123/TCP,9000/TCP                35m
      clickhouse-simple-01          ClusterIP     None           <none>         8123/TCP,9000/TCP                3d7h
  3. Access the ClickHouse database.
    kubectl -n test-clickhouse-operator exec -ti chi-ck-elb-ck-elb-0-0-0 -- clickhouse-client
    ClickHouse client version 23.8.16.16 (official build).
    Connected to ClickHouse server version 23.8.16 revision 54465.
    Warnings:
    chi-ck-elb-ck-elb-0-0-0.chi-ck-elb-ck-elb-0-0.test-clickhouse-operator.svc.cluster.local :)
  4. Clear the ClickHouse cluster resources.
    Delete the ClickHouse cluster that contains the LoadBalancer Service.
    kubectl delete -f elb.yaml  -n test-clickhouse-operator
    clickhouseinstallation.clickhouse.altinity.com "ck-elb1" deleted
Follow-up Operations: Clearing Other ClickHouse Resources
  1. Delete the test-clickhouse-operator namespace.
    kubectl delete namespace test-clickhouse-operator
    namespace "test-clickhouse-operator" deleted
  2. Delete the ClickHouse Operator:
    kubectl delete -f clickhouse-operator-install-bundle.yaml
    customresourcedefinition.apiextensions.k8s.io "clickhouseinstallations.clickhouse.altinity.com" deleted
    customresourcedefinition.apiextensions.k8s.io "clickhouseinstallationtemplates.clickhouse.altinity.com" deleted
    customresourcedefinition.apiextensions.k8s.io "clickhouseoperatorconfigurations.clickhouse.altinity.com" deleted
    customresourcedefinition.apiextensions.k8s.io "clickhousekeeperinstallations.clickhouse-keeper.altinity.com" deleted
