Range
Application Scenarios
This algorithm applies to routing data in different ranges to different shards. Less-than signs (<), greater-than signs (>), and BETWEEN ... AND ... are frequently used in SQL queries.
Instructions
A sharding key can only be an integer, a date, or used in combination with a date function. If a date function is used, the sharding key must be of the DATE, DATETIME, or TIMESTAMP type.
A sharding key is generally the table field or the table field+date function. If the sharding key is the table field+date function, the table field must be DATE, DATETIME, or TIMESTAMP. The date function applies to routing data to different shards by year, month, week, day, or a combination of them.
Data Routing
Data is routed to different shards by the sharding key value based on algorithm metadata rules.
Calculation Method
Method 1: Use an Integer as the Sharding Key
| Condition | Calculation Method | Example |
| Integer sharding keys | Database routing result: Data is routed to different shards based on the sharding key and the preset metadata range. Table routing result: Data is routed to different sharded tables based on the sharding key and the preset metadata range. | Data is routed to shard1 if the sharding key value is 3 and the preset metadata range is 3–4. Data is routed to shard2 if the sharding key value is 5 and the preset metadata range is 5–6. |
Method 2: Use a Date as the Sharding Key
| Date Function | Calculation Method | Example |
| year() | year(yyyy-MM-dd)=yyyy | year('2019-10-11')=2019 |
| month() | month(yyyy-MM-dd)=MM | month('2019-10-11')=10 |
| weekofyear() | weekofyear(yyyy-MM-dd)=Week of the current year | weekofyear ('2019-10-11')=41 |
| day() | day(yyyy-MM-dd)=Day of the current month | day ('2019-10-11')=11 |
| Date sharding key | Database routing: Data is routed to different database shards based on the date function (database sharding key value) and the preset metadata range. Table routing: Data is routed to different table shards based on the date function (sharding key value) and the preset metadata range. | Data is routed to shard4 based on the metadata range 9–10 when the sharding key value is 10: month(2019-10-11)=10 belongs to 9–10=4. |
Syntax for Creating Tables
create table range_tb(
    id int,
    name varchar(30) DEFAULT NULL,
    create_time datetime DEFAULT NULL,
    primary key(id)
dbpartition by range(id)
    1-2=0,
    3-4=1,
    5-6=2,
    7-8=3,
    9-10=4,
    11-12=5,
    13-14=6,
    default=7
 Precautions
- The sharding key and its value cannot be modified.
- The range algorithm can be used only for database sharding.
