- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Pipeline Usage
- Enabling and Authorizing CodeArts Pipeline
- Accessing CodeArts Pipeline
- Creating a Pipeline
- Configuring a Pipeline
- Grouping Pipelines
- Executing a Pipeline
- Checking a Pipeline
- Configuring a Change-triggered Pipeline
- Managing Pipeline Extensions
- Creating Service Endpoints
- Checking Audit Logs
- Reference
- CodeArts Release User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Template Management
Pipeline Management
- Starting a Pipeline
- Obtaining Pipeline Statuses in Batches
- Obtaining Pipeline Status/Obtaining Pipeline Execution Details
- Obtaining Pipeline List/Pipeline Execution Status in a Project
- Deleting a Pipeline
- Querying Pipeline Details
- Editing a Pipeline
- Stopping a Pipeline
- Obtaining Pipeline Execution Records
- Creating a Pipeline With a Template
- Retrying a Pipeline
- Passing Manual Review
- Rejecting Manual Review
- Querying Pipeline Logs
- Obtaining the Pipeline Step Execution Output
- Querying Build Products on a Pipeline
- Group Management
- Rule Management
- Tenant-level Policy Management
- Project-level Policy Management
Extension Management
- Creating an Extension Version
- Creating an Extension Draft Version
- Creating a Publisher
- Updating an Extension Draft
- Publishing an Extension Draft
- Updating Basic Information of an Extension
- Binding an Extension to a Publisher
- Updating the Extension Icon
- Updating the Publisher Icon
- Deleting an Extension Draft
- Querying the Publisher List
- Querying the Available Publisher
- Querying the Available Extension List
- Querying the Basic Extension List
- Querying the Available Extensions by Page
- Querying the Extension List
- Querying Extension Indicator Configuration
- Query Extension Input Configuration
- Query Extension Output Configuration
- Querying All Versions of an Extension
- Querying Extension Version Details
- Querying the Extension Version
- Deleting a Publisher
- Querying Publisher Details
- Creating a Basic Extension
- Updating a Basic Extension
- Deleting a Basic Extension
- Uploading a Basic Extension
- Querying the Basic Extension Details
- Template Management (Old Version, Unavailable Soon)
Pipeline Management (Old Version, Unavailable Soon)
- Quickly Creating a Pipeline and Jobs with a Template
- Checking the Pipeline Creation Status
- Obtaining the Pipeline List
- Obtaining the Pipeline Status
- Obtaining the Pipeline Execution Status in a Project
- Application Examples
- Appendixes
- Change History
- Functions
Troubleshooting
- Pipeline Fails to Run Because Repository Not Found
- Pipeline Fails to Run Because the Test Suite Is Already in Progress
- Pipeline Fails to Run Because Job Not Found
- Pipeline Is Not Triggered at a Specified Time
- Execution Button Is Unavailable
- Inappropriate Reviewer Configured for the Manual Review Job
- Subpipeline Not Found
- Change-triggered Pipeline Fails to Run and an Error Message Is Returned: "authentication required"
- Pipeline Fails to Run Because Deployment Policy Not Found
- Videos
Show all
Pipeline Official Extensions
CodeArts Pipeline provides official extensions as listed in Table 1.
Type |
Name |
Description |
Build |
Build |
Calls CodeArts Build capabilities. CodeArts Build provides an easy-to-use, cloud-based build platform that supports multiple programming languages, helping you achieve continuous delivery with shorter period and higher efficiency. With CodeArts Build, you can create, configure, and run build tasks with a few clicks. CodeArts Build also supports automated code retrieval, build, and packaging, as well as real-time status monitoring. Learn more. |
Build-Template |
This extension can be configured only in a pipeline template. When a pipeline is generated based on the template, the extension automatically creates a build job and configures the job in the generated pipeline. |
Test |
TestPlan |
Calls CodeArts TestPlan capabilities. CodeArts TestPlan is a one-stop cloud testing platform provided for software developers. It covers test management and API tests and integrates the DevOps agile testing concepts, helping you improve management efficiency and deliver high-quality products. Learn more. |
TestPlan-Template |
This extension can be configured only in a pipeline template. When a pipeline is generated based on the template, the extension automatically creates an API test job and configures the job in the generated pipeline. |
Deploy |
Deploy |
Calls CodeArts Deploy capabilities. CodeArts Deploy allows you to visually deploy applications in VMs or containers by using Tomcat, Spring Boot, and other templates. You can also flexibly orchestrate atomic actions for deployment. CodeArts Deploy standardizes your deployment environment and processes by integrating with CodeArts Pipeline. Learn more. |
Deploy-Template |
This extension can be configured only in a pipeline template. When a pipeline is generated based on the template, the extension automatically creates a deployment job and configures the job in the generated pipeline. |
KubernetesRelease |
Allows you to deploy container images to Cloud Container Engine (CCE) or native Kubernetes clusters. It supports rolling release and blue-green deployment. |
CloudNativeRelease |
Allows you to orchestrate release policies for environments, such as rolling release and grayscale release. |
Check |
Check |
Calls CodeArts Check capabilities. CodeArts Check is a cloud-based management service that checks code quality. Developers can easily perform static code and security checks in multiple languages and obtain comprehensive quality reports. CodeArts Check also provides bug fixing suggestions and trend analysis to control code quality and reduce costs. Learn more. |
Check-Template |
This extension can be configured only in a pipeline template. When a pipeline is generated based on the template, the extension automatically creates a Check job and configures the job in the generated pipeline. |
BranchCheck |
Specifies the target branch. If the current running branch lags behind the specified branch, the pipeline fails to run. |
Normal |
CreateTag |
Creates and pushes tags for code repositories. |
Subpipeline |
Configures and calls other pipeline tasks in a project. |
JenkinsTask |
Calls Jenkins tasks. Currently, this function is available in LA-Mexico City2, LA-Sao Paulo1, and AP-Singapore. |
DelayedExecution |
Pauses pipeline for a period of time or until a specified time. You can manually resume or stop a pipeline, or delay the execution for a maximum of three times. |
ManualReview |
Creates manual review tasks by assigning one person or one group. |
GitClone |
Clones the code repositories configured in the pipeline source, which can be used together with shell commands and Maven build. Currently, GitClone is available in LA-Mexico City2, LA-Sao Paulo1, AP-Singapore, and TR-Istanbul. |
ExecuteShellCommand |
Runs shell commands. |
Microservice |
CreateReleaseBranch |
Creates a release branch based on the default branch of a microservice. This extension is automatically configured by a change-triggered pipeline. |
MergeReleaseBranch |
Merges a feature branch into a release branch. This extension is automatically configured by a change-triggered pipeline. |
MergeDefaultBranch |
Merges a release branch into the default branch of a microservice. This extension is automatically configured by a change-triggered pipeline. |
Pass conditions |
Pass-Conditions-of-Standard-Policies |
A standard extension policy for gate control. |
