Pipeline Contexts
Contexts are a way to access information about pipeline runs, sources, variables, and jobs. Each context is an object that contains various attributes. The following table lists pipeline contexts.
Context |
Type |
Description |
pipeline |
object |
Information about the pipeline run. |
sources |
object |
Information about the pipeline sources in each pipeline run. |
env |
object |
Information about the custom parameters in each pipeline run. |
jobs |
object |
Information about jobs that have reached the final states in each pipeline run. |
Context Reference Format
${{ <context>.<attribute_name> }}
context indicates the pipeline context, attribute_name indicates the attribute.
Contexts Attributes
Context |
Attribute |
Type |
Description |
Example |
pipeline context |
pipeline |
object |
Information about the pipeline run. This object contains the following attributes: project_id, pipeline_id, run_number, timestamp, trigger_type, and run_id. |
pipeline.project_id |
string |
ID of the project to which the current pipeline belongs. This string is the same as the predefined parameter PROJECT_ID. |
pipeline.pipeline_id |
string |
Current pipeline ID. This string is the same as the predefined parameter PIPELINE_ID. |
pipeline.run_number |
string |
Pipeline execution number. This string is the same as the predefined parameter PIPELINE_NUMBER. |
pipeline.timestamp |
string |
Pipeline execution timestamp. This string is the same as the predefined parameter TIMESTAMP. The format is yyyyMMddHHmmss. For example, 20211222124301. |
pipeline.trigger_type |
string |
Pipeline triggering type. This string is the same as the predefined parameter PIPELINE_TRIGGER_TYPE. |
pipeline.run_id |
string |
Pipeline execution ID. This string is the same as the predefined parameter PIPELINE_RUN_ID. |
sources context |
sources |
object |
Information about the pipeline sources in each pipeline run. This object contains the following attributes: alias, repo_name, commit_id, commit_id_short, commit_message, repo_url, repo_type, repo_name, ssh_repo_url, tag, merge_id, source_branch, and target_branch. |
sources.<alias> |
object |
Information about the pipeline source which has an alias. |
sources.<repo_name> |
object |
Information about the pipeline source which does not have an alias but only a repository name. It contains the same information as that in sources.<alias>. |
sources.<alias>.commit_id |
string |
The last commit ID before execution. This string is the same as the predefined parameter COMMIT_ID. |
sources.<alias>.commit_id_short |
string |
The first 8 characters of the last commit ID before execution. This string is the same as the predefined parameter COMMIT_ID_SHORT. |
sources.<alias>.commit_message |
string |
The commit information from the last code commit before the pipeline execution. |
sources.<alias>.repo_url |
string |
Code repository address (HTTPS). This string is the same as the predefined parameter REPO_URL. |
sources.<alias>.repo_type |
string |
Type of the code repository. For example, codehub, gitlab, github, gitee, and general_git. |
sources.<alias>.repo_name |
string |
Name of the code repository. |
sources.<alias>.ssh_repo_url |
string |
Code repository address (SSH). |
sources.<alias>.tag |
string |
Tag name when the tag is triggered. |
sources.<alias>.merge_id |
string |
Merge request ID when the merge request is triggered. |
sources.<alias>.source_branch |
string |
Source branch name when the merge request is triggered. |
sources.<alias>.target_branch |
string |
If the merge request is triggered, this string indicates the name of the target branch. Otherwise, this string indicates the name of the running branch. |
env context |
name |
string |
Name of a custom parameter. |
value |
string |
Value of a custom parameter. |
jobs context |
jobs |
object |
Information about jobs in a pipeline. This object contains the following attributes: job_id, status, outputs, output_name, metrics, and metric_name. |
jobs.<job_id> |
object |
Information about the job with a specified ID. |
jobs.<job_id>.status |
string |
Job execution result. The value can be INIT, QUEUED, RUNNING, CANCELED, COMPLETED, FAILED, PAUSED, IGNORED, SUSPEND, or UNSELECTED. |
jobs.<job_id>.outputs |
object |
The running value, as a key-value pair. |
jobs.<job_id>.outputs.<output_name> |
string |
The running value name. |
jobs.<job_id>.metrics |
object |
The running metrics of a job. For example, the number of code check issues and the test pass rate. |
jobs.<job_id>.metrics.<metric_name> |
string |
The running metric name of a job. |
Related Information
The following are context scenarios:
