Updated on 2026-04-23 GMT+08:00
Overview of Lifecycle Management
The last modification time of an object determines when the lifecycle rule applied to the object becomes effective to periodically transition or delete the object. The transition action is to automatically change objects that are no longer frequently accessed to a storage class with a lower cost without copying the objects themselves.
Figure 1 OBS object lifecycle management
Table 1 Key actions in OBS object lifecycle management
Action
Objects Managed
Operation Guide
Transitions between storage classes
Periodically transition data that is frequently accessed over a period of time but may not be accessed after that period to the Archive or Deep Archive storage class to reduce storage costs. Such data includes digital media, financial and medical records, long-term database backups, and data retained for regulatory compliance.
Objects in a bucket (including the latest and historical versions of objects when versioning is enabled for the bucket)
Transitioning Objects Using Lifecycle Rules
Periodic deletion of objects
Periodically delete data, such as log files, that needs to be retained for a period of time and can be deleted after that period.
  • Objects in a bucket (including the latest and historical versions of objects when versioning is enabled for the bucket)
  • Fragments
    In a multipart upload, a file is divided into multiple parts and then uploaded. After all parts are uploaded, you can make an API call to assemble the parts into a complete object. The parts that failed to be uploaded or assembled are called fragments. You can continue to execute the interrupted or failed multipart upload to remove fragments, or directly delete fragments to reduce storage costs. For more information about fragments, see Deleting Fragments.
  • Expired delete markers
    An expired delete marker is the only single delete marker that remains after all historical versions of an object are deleted. Removing expired delete markers helps improve performance.
Deleting Objects Using Lifecycle Rules
Points in Time for Lifecycle Management
Below describes the key points in time involved in lifecycle management.
  • Appending data to an object changes the last modification time of the object. In contrast, operations, such as changing an object's storage class, ACL, metadata, or encryption settings, do not modify the object content or last modification time. They update only the object's metadata.
  • For parallel file systems, modifying and truncating a file will change the last modification time of the file.
  • Uploading or copying an object in a bucket or a file in a parallel file system will change their last modification time if there is such an object or a file with the same name. If versioning is not enabled, the last modification time of the object or file is the time when the object or file was last uploaded. If versioning is enabled, a newly uploaded object or file becomes the current version, and the original one becomes a historical version. The last modification time of both the current version and the historical version is the time when the object or file was last uploaded.
After an object is last updated, OBS starts to calculate its lifecycle at the next 00:00 (UTC time). Assume an object was uploaded at 09:00 on June 1, 2024 (UTC). OBS would calculate its lifecycle from 00:00 on June 2, 2024 (UTC). If the object was configured to be deleted one day later, it would be deleted at 00:00 on June 3, 2024 (UTC).
  • It usually takes 24 hours at most for the actions in a lifecycle rule to complete. Considering the start time of the rule, there may be a delay in transitioning storage classes or deleting expired objects, but the total completion time will not exceed 48 hours.
    Assume an object was uploaded at 09:00 on June 1, 2024 (UTC). OBS would calculate its lifecycle from 00:00 on June 2, 2024 (UTC). If the object was configured to be deleted one day later, it would be deleted at 00:00 on June 3, 2024 (UTC). The execution latency does not exceed 24 hours and the deletion would be completed at 00:00 on June 4, 2024 (UTC).
  • If you make changes to an existing lifecycle rule, the lifecycle task on the current day will be terminated and the lifecycle execution time may be prolonged. Therefore, do not frequently change a lifecycle rule. For example, if an object was uploaded at 20:20 on June 1, 2024 (UTC) and configured to be deleted one day later, it would be deleted at 00:00 on June 4, 2024 (UTC) at the latest. However, if the lifecycle rule was modified, for example, the rule name was changed, the lifecycle rule would be reloaded and executed again and the deletion may be completed later than 00:00 on June 4, 2024 (UTC).
  • Up to 500 million lifecycle-related operations (including deleting objects, changing object storage classes, and deleting fragments) can be performed on a single bucket within 24 hours. If you have higher requirements, submit a service ticket.
Billing for Lifecycle Management
If you have configured any lifecycle rules, you will be billed for the actions listed in the tables below.
Table 2 Billing for lifecycle management actions (during action execution)
Action
Billing Item
Billing Mode
Delete after expiration
Requests
You are billed for the number of successfully deleted objects.
Pay-per-Use
Storage space
If objects are deleted before they have been stored for the required minimum duration (180, 90, and 30 days for Deep Archive, Archive, and Infrequent Access storage, respectively), you still need to pay for the remaining days.
Pay-per-Use
Resource packages
Transition from Standard to Infrequent Access
Infrequent Access PUT requests
You are billed for the number of successfully transitioned objects. If N objects are successfully transitioned, you are billed for N requests.
Pay-per-Use
Transition from Standard to Archive
Archive PUT requests
Pay-per-Use
Transition from Infrequent Access to Archive
Transition from Standard to Deep Archive
Deep Archive PUT requests
Pay-per-Use
Transition from Infrequent Access to Deep Archive
Transition from Archive to Deep Archive
Table 3 Billing for lifecycle management actions (after action execution)
Action
Billing Item
Billing Mode
N/A
After the deletion is executed, objects have been deleted, so no more billing applies.
N/A
After the transition, you will be billed for the Infrequent Access storage.
Pay-per-Use
Archive storage
After the transition, you will be billed for the Archive storage.
Pay-per-Use
Archive storage resource packages
Archive storage
  1. After the transition, you will be billed for the Archive storage.
  2. Infrequent Access has a minimum storage duration of 30 days. If Infrequent Access objects are transitioned to Archive before this minimum duration is reached, you still need to pay for Infrequent Access storage of the remaining days.
After the transition, you will be billed for the Deep Archive storage.
Pay-per-Use
  1. After the transition, you will be billed for the Deep Archive storage.
  2. Infrequent Access has a minimum storage duration of 30 days. If Infrequent Access objects are transitioned to Deep Archive before this minimum duration is reached, you still need to pay for Infrequent Access storage of the remaining days.
  2. Archive has a minimum storage duration of 90 days. If Archive objects are transitioned to Deep Archive before this minimum duration is reached, you still need to pay for Archive storage of the remaining days.
