Server-Side Encryption Overview
Server-side encryption helps secure data stored in OBS and meet compliance requirements. It encrypts data at rest, storing data as ciphertext on physical storage media like hard disks. This ensures that even if the media is lost or accessed without authorization, the data remains protected. When the data is accessed, the OBS server decrypts it and then returns the plaintext data.
OBS supports three encryption methods: server-side encryption with KMS-managed keys (SSE-KMS), server-side encryption with OBS-managed keys (SSE-OBS), and server-side encryption with customer-provided keys (SSE-C).
| Comparison Dimension | SSE-KMS | SSE-OBS | SSE-C |
| Scenarios | Scenarios that require high compliance and security. Keys are generated by third-party validated Hardware Secure Modules (HSMs). Access to keys is controlled and all operations involving keys are traceable by logs. | Scenarios that require basic encryption and batch processing. OBS does not need to interact with KMS. SSE-OBS features lower access latency and better performance than SSE-KMS. | Scenarios that users need to store and manage keys by themselves |
| Key management | KMS generates and keeps keys, and OBS uses the keys to encrypt objects. | OBS generates and keeps keys, and uses the keys to encrypt objects. | A user generates and keeps keys, and OBS uses the keys to encrypt objects. |
| Encryption algorithm | AES-256 and SM4 | AES-256 | AES-256 |
| Encryption scope | Bucket level and object level | Bucket level and object level | Object level |
| Details | See SSE-KMS. | See SSE-OBS. | See SSE-C. |
- SSE-KMS is supported only in the regions shown as available on OBS Console. If you want to use the SM4 encryption algorithm when enabling SSE-KMS, choose the CN North-Ulanqab1 region.
- SSE-C is available in the regions where the SSE-C API is supported.
- Only one encryption method can be used each time an object is uploaded. The encryption configuration of an uploaded object cannot be changed.
- To use SSE-KMS to encrypt a bucket or the objects in it, you must have kms:cmk:get, kms:cmk:list, kms:cmk:create, kms:dek:create, and kms:dek:crypto permissions granted by using IAM, so that you can upload objects to or download objects from this bucket.
- If server-side encryption is disabled for a bucket, the encrypted objects can only be accessed over HTTPS.
- A key in use cannot be deleted, or the object encrypted with this key cannot be downloaded.
Bucket-Level and Object-Level Server-Side Encryption
The following table compares bucket-level and object-level server-side encryption.
| Item | Bucket-Level Encryption | Object-Level Encryption |
| Scenarios | You need to encrypt all objects when they are uploaded to a bucket. | You need to encrypt only some objects or select an encryption method and key each time you upload an object. |
| Encryption methods | SSE-KMS and SSE-OBS | SSE-KMS, SSE-OBS, and SSE-C |
| Configuration | You can change your encryption configuration at any time. | You can configure encryption during object upload and the configuration cannot be changed after the upload. |
| Impacts |
References
- You can use Cloud Trace Service (CTS) to monitor bucket encryption operations, including setBucketEncryption (which configures server-side encryption for a bucket) and deleteBucketEncryption (which deletes the bucket's server-side encryption settings). For more information, see Using CTS to Audit OBS.
- You can enable logging for OBS to automatically log bucket encryption operations, including REST.PUT.ENCRYPTION (which configures encryption for a bucket), REST.GET.ENCRYPTION (which obtains the bucket's encryption settings), and REST.DELETE.ENCRYPTION (which deletes the bucket's encryption settings). OBS writes the generated log files to the specified bucket. For more information, see Configuring Logging for a Bucket.
