Updated on 2025-07-28 GMT+08:00
SQL Mathematical Functions
Mathematical functions are one type of scalar functions. They support only numeric fields and can be used to round values, obtain absolute values, and perform modulo operations. For details, see Table 1.
In mathematical operations, if the operands involved in an expression are all integers, SQL uses integer operations. Otherwise, SQL switches to floating-point operations. You can force the switch by converting one of the operands to float type, and the runtime SQL extends the 32-bit floats in most expressions to 64-bit floats.
Syntax
SELECT ABS(fieldname1) AS fieldname1_abs
Mathematical Function Statements
Table 1 Mathematical function statements
Statement
Example
ABS(expr)
Returns the absolute value.
CEIL(expr)
Rounds up to the nearest integer.
SELECT CEIL(fieldname1)
FLOOR(expr)
Rounds down to the nearest integer.
SELECT FLOOR(fieldname1)
TRUNCATE(expr, digits)
Truncates expr to a specified number of digits. If digits is set to a negative number, places to the left of the decimal point are truncated. If digits is not specified, the default value 0 is used.
SELECT TRUNCATE(fieldname1, 2)
ROUND(expr, digits)
Rounds the value of expr to a specified number of decimal places. The result has the same type as expr. expr can be an integer or a floating point number, while digits must be an integer. If digits is not specified, the default value 0 is used. If digits is a negative number, the value of expr is rounded off. If expr is a non-numeric value, it will be converted to 0. If expr is an infinite number, it is converted to the closest finite number of the double type.
SELECT ROUND(fieldname1, 2)
x + y
Addition.
SELECT fieldname1 + fieldname2
x - y
Subtraction.
SELECT fieldname1 - fieldname2
x * y
Multiplication.
SELECT fieldname1 * fieldname2
x / y
Division.
SELECT fieldname1 / fieldname2
MOD(x, y)
Modulo. It returns a remainder obtained after x is divided by y.
SELECT MOD(fieldname1, fieldname2)
LN(expr)
Logarithm (base: e).
SELECT ln(expr)
LOG10(expr)
Logarithm (base 10).
SELECT LOG10(expr)
POWER(expr,power)
Power of expr.
SELECT POWER(expr ,2)
SQRT(expr)
Square root of expr.
SELECT SQRT(expr)
SIN(expr)
Sine.
SELECT SIN(expr)
COS(expr)
Cosine.
SELECT COS(expr)
TAN(expr)
Tangent.
SELECT TAN(expr)
COT(expr)
Cotangent.
SELECT COT(expr)
ASIN(expr)
Arcsine.
SELECT ASIN(expr)
ACOS(expr)
Arc cosine.
SELECT ACOS(expr)
ATAN(expr)
Inverse tangent.
SELECT ATAN(expr)
Examples
ACOS(expr)
Calculates the arccosine of a parameter value. y = arccosx, where x is within [-1,1].
  1. Example field
    x:0.5
  2. Query and analysis statement
    select  ACOS(x)
  3. Query and analysis result
    Table 2 Query and analysis result
    x
    EXPR$1
    0.5
    1.0471975511965979
ATAN(expr) function
Calculates the arctangent of a parameter value. y = arctanx, where x is R.
  1. Example field
    x:0.5
    select  ATAN(X)
    Table 3 Query and analysis result
    x
    EXPR$1
    0.5
    1.0471975511965979
ATAN2(expr)
Returns the angle θ from rectangular coordinates (x, y) to polar coordinates (r, θ).
  1. Example field
    x:3; y:4
    SELECT x , y, ATAN2(x,y)
    Table 4 Query and analysis result
    x
    y
    EXPR$0
    3
    4
    0.6435011087932844
