Monitoring Metrics
Overview
This section describes the namespace, list, and measurement dimensions of metrics of EIPs and bandwidths that you can check on Cloud Eye. You can use APIs or the Cloud Eye console to query the monitored metrics and generated alarms.
- Cloud Eye can monitor dimensions nested to a maximum depth of four levels (levels 0 to 3). 3 is the deepest level. For example, if the monitored dimension of a metric is resourceA_id,resourceB_id, resourceA_id indicates level 0 and resourceB_id indicates level 1.
- If a bandwidth is increased or decreased, there is a delay of 5 to 10 minutes for the monitoring metrics to update for the new bandwidth.
Namespace
Namespace of EIPs and bandwidths: SYS.VPC
Monitoring Metrics
| ID | Name | Description | Value Range | Unit | Conversion Rule | Monitored Object (Dimension) | Monitoring Interval (Raw Data) |
| upstream_bandwidth | Outbound Bandwidth | Network rate of outbound traffic (Previously called "Upstream Bandwidth") | ≥ 0 | bit/s | 1000 (SI) | bandwidth_id publicip_id | 1 minute |
| downstream_bandwidth | Inbound Bandwidth | Network rate of inbound traffic (Previously called "Downstream Bandwidth") | ≥ 0 | bit/s | 1000 (SI) | bandwidth_id publicip_id | 1 minute |
| upstream_bandwidth_usage | Outbound Bandwidth Usage | Usage of outbound bandwidth in the unit of percent. Outbound bandwidth usage = Outbound bandwidth/Purchased bandwidth | 0-100 | % | N/A | bandwidth_id publicip_id | 1 minute |
| downstream_bandwidth_usage | Inbound Bandwidth Usage | Usage of inbound bandwidth in the unit of percent. Inbound bandwidth usage = Inbound bandwidth/Purchased bandwidth | 0-100 | % | N/A | bandwidth_id publicip_id | 1 minute |
| up_stream | Outbound Traffic | Network traffic going out of the cloud platform (Previously called "Upstream Traffic") | ≥ 0 | Byte | 1000 (SI) | bandwidth_id publicip_id | 1 minute |
| down_stream | Inbound Traffic | Network traffic going into the cloud platform (Previously called "Downstream Traffic") | ≥ 0 | Byte | 1000 (SI) | bandwidth_id publicip_id | 1 minute |
Dimensions
| Key | Value |
| publicip_id | EIP ID You can call the API Querying an EIP to obtain the value from the response parameters. |
| bandwidth_id | Bandwidth ID You can call the API Querying a Bandwidth to obtain the value from the response parameters. |
