Adding a Route for an Enhanced Datasource Connection
Enhanced datasource connections establish peering connections between DLI elastic resource pools and data sources to interconnect two VPC networks. If we liken these peering connections to exclusive bridges linking elastic resource pools and data sources, then routing serves as directional signage guiding the flow of network traffic.
Routing rules determine the direction of network traffic by configuring information such as the destination address, next hop type, and next hop address. Routes are classified into system routes and custom routes.
After an enhanced datasource connection is created, the subnet is automatically associated with the system default route. Besides the system default route, you can add custom routing rules as needed to forward traffic destined for the target address to the specified next-hop address.
- When an enhanced connection is created, the associated route table is the one associated with the subnet of the data source.
- The route to be added in the Add Route dialog box must be one in the route table associated with the subnet of the resource pool.
- The data source subnet and the elastic resource pool subnet must be different subnets to avoid network segment conflicts.
- Log in to the DLI management console.
- In the navigation pane on the left, choose Datasource Connections.
- On the displayed Enhanced tab, locate the enhanced datasource connection where you want to add a route and then add a route.
- Method 1:
- On the Enhanced tab, locate the enhanced datasource connection where you want to add a route and click Manage Route in its Operation column.
- On the displayed page, click Add Route.
- In the Add Route dialog box, set the parameters based on Table 1.
- Click OK.
- Method 2:
- On the Enhanced tab, locate the enhanced datasource connection where you want to add a route, click More in its Operation column, and select Add Route.
- Click OK.
Table 1 Parameters for adding a custom route Parameter
Route Name
Name of a custom route, which is unique in the same enhanced datasource connection. The name can contain up to 64 characters. Only digits, letters, underscores (_), and hyphens (-) are allowed.
IP Address Type
The options are IPv4 and IPv6.
If your data source has IPv6 enabled and the current enhanced datasource connection supports IPv6, you can select IPv6 routes when adding a route table.
You can check whether the current enhanced datasource connection supports IPv6 in its basic information. For details, see Viewing Basic Information About an Enhanced Datasource Connection.
The route IP address example is as follows:
- IPv4 address: 192.168.2.0/24.
- IPv6 address: 2407:c080:802:be7::/64.
IP Address
Custom route CIDR block. The CIDR blocks of different routes can overlap but cannot be identical.
Do not add the 100.125.xx.xx or 100.64.xx.xx CIDR blocks to avoid conflicts with the internal CIDR blocks of services like SWR, which can cause enhanced datasource connections to fail.
- Method 1:
- After adding a route, you can view the route information on the route details page.
