Help Center/ Data Lake Insight/ User Guide/ Configuring DLI to Read and Write Data from and to External Data Sources/ Managing Enhanced Datasource Connections/ Deleting the Route for an Enhanced Datasource Connection
Updated on 2026-05-26 GMT+08:00
Delete a route that is no longer used.
Notes and Constraints
A custom route table cannot be deleted if it is associated with a subnet.
- Log in to the DLI management console.
- In the navigation pane, choose Datasource Connections.
- On the displayed Enhanced tab, locate the enhanced datasource connection where you want to delete a route and then delete a route.
- Method 1:
- On the Enhanced tab, locate the enhanced datasource connection where you want to delete a route and click Manage Route in its Operation column.
- Locate the route to be deleted and click Delete in the Operation column.
- In the dialog box displayed, click OK.
- Method 2:
- On the Enhanced tab page displayed, locate the enhanced connection from which the route needs to be deleted, click More in the Operation column, and select Delete Route.
- In the Delete Route dialog box displayed, confirm the route information.
- Click Yes.
- Method 1:
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
