Unbinding an Enhanced Datasource Connection from an Elastic Resource Pool
Unbind an enhanced datasource connection from an elastic resource pool that does not need to access a data source through an enhanced datasoruce connection.
Notes and Constraints
If the status of the VPC peering connection created for binding an enhanced datasource connection to an elastic resource pool is Failed, the elastic resource pool cannot be unbound.
- Log in to the DLI management console.
- In the navigation pane, choose Datasource Connections.
- On the Enhanced tab page displayed, use either of the following methods to unbind an enhanced datasource connection from an elastic resource pool:
- Method 1:
- Locate your desired enhanced datasource connection, click More in the Operation column, and select Unbind Resource Pool.
- In the Unbind Resource Pool dialog box, select the resource pool to be unbound for Resource Pool.
- Click OK.
- Method 2:
- Click your desired enhanced datasource connection in the list.
- Locate your desired resource pool and click Unbind Resource Pool in the Operation column.
- Click OK.
- Method 1:
