- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Jobs/
Atomic Action/
Execute Command
Execute Command
The atomic action can be used to execute a specific command.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Jobs.
Figure 1 Jobs
- Click the Custom Jobs tab and click Create Job.
Figure 2 Clicking Create Job
- Enter the basic job information. You can follow the steps in section Managing Tags to create a tag. After the required parameters are set, click Next.
Figure 3 Entering basic job information
- Select a job template. If no proper template is available, click Customize, and click Next.
Figure 4 Selecting a job template
- Perform job orchestration. Click + Add Task, and click + Operation Type. On the displayed dialog box, click Execute Command.
Figure 5 Adding tasks
- Enter the task name and operation description.
Figure 6 Setting the basic information
- Click Input, set commandType (Command type) to SHELL, PYTHON, or BAT as required. Set executeUser (command execution os user), timeout (Command execution timeout (second), successRate (Success rate (%)), commandContent (Command content), and commandParams (Command execute inputs).
Figure 7 Adding input information
- Click Troubleshooting and configure the policy for the action upon an execution error: Terminate Job or Go to Next Step.
Figure 8 Adding troubleshooting policy
- Click OK.
Parent topic: Atomic Action
