- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Application and Resource Management/
Cross-Account Resources/
Creating a View
Creating a View
Allows users to create views and configure the filter scope to access Huawei Cloud resources across accounts.
Create a view on Cloud Operations Center.
Precautions
A maximum of 10 views can be created.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management and click Cross-Account Resources.
- Click View Management.
Figure 1 View management
- Click Create View. In the dialog box that is displayed on the right, enter information based on Table 1 and click OK.
Figure 2 View management
Parent topic: Cross-Account Resources
