Updated on 2025-08-08 GMT+08:00
Deleting a Group
After a group is created, you can delete it by following the operations in this section.
Deleting a Group
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, expand the target application, select the target group, and click .
  5. Click OK.
    The group is deleted.
