Updated on 2026-06-23 GMT+08:00
Managing IDC Resources
As enterprises' architectures diversify, they increasingly depend on both cloud resources and on‑premises devices to ensure stable services running. The core requirement is to use one platform to centrally manage the two types of resources to avoid efficiency loss caused by scattered operations to ensure smooth O&M. Under traditional O&M practices, cloud resources and on-premises devices are managed independently using different tools. O&M personnel must frequently switch between these systems. This approach increases workload, and can result in inconsistent data and fragmented processes. As a result, services lack a seamless O&M workflow and cannot achieve unified resource control. How can the divide between cloud and on‑premises environments be removed so that both cloud resources and on‑premises devices can be centrally managed through a single O&M platform? COC empowers you to effortlessly tackle this challenge by offering all-scenario resource management capabilities that seamlessly integrate both cloud and on-premises environments. When you manage on-premises physical machines, VMs, and middleware on Huawei Cloud, for example, resource statistics collection and unified resource O&M, the robust IDC resource management feature ensures streamlined operations. With this feature, COC breaks down the management barriers between cloud and on-premises environments, enabling unified and standardized O&M across all resources. This helps enterprises boost O&M efficiency while reducing management costs.
To use the IDC resource management capability, upgrade the version first. For details about the package, see Billing Items.
Importing IDC Resources
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Multi-cloud Configurations in the upper right corner.
  4. On the Multi-cloud Configurations page, click On-premises IDCs.
  5. Select the desired import type and region.
    You can set Import Type to Physical machine, Virtual machine, or Middleware device.
  6. Click Download Template and enter related information in the template.
    Table 1 Physical machine parameters
    Constraint
    Xrn
    Unique ID of the physical machine.
    (Mandatory) The value can contain a maximum of 128 characters.
    Name
    Name of the physical machine.
    Serial Number
    Serial number of the physical machine.
    Private IP
    Private IP address of the physical machine.
    (Mandatory)
    PM Model
    Type of the physical machine.
    (Mandatory) The value can contain a maximum of 64 characters.
    Manufacturer
    Vendor of the physical machine.
    OS Type
    OS
    (Mandatory) The value can only be LINUX or WINDOWS.
    UniAgent ID
    Unique ID of UniAgent.
    (Optional) The value can contain a maximum of 128 characters.
    Description of the physical machine.
    (Optional) The value can contain a maximum of 256 characters.
    Table 2 Virtual machine parameters
    Constraint
    Xrn
    Unique ID of the virtual machine.
    Name
    Name of the virtual machine.
    Private IP
    Private IP address of the virtual machine.
    (Mandatory)
    OS Type
    OS
    ECS ID
    Unique ID generated by OpenStack.
    UniAgent ID
    Description of the virtual machine.
    Table 3 Middleware parameters
    Constraint
    Xrn
    Unique ID of the middleware.
    Name
    Middleware name.
    Middleware Model
    Middleware type, for example, MySQL.
    Version
    Version
    (Optional) The value can contain a maximum of 64 characters.
    Port
    Port
    (Optional) The port number ranges from 0 to 65535.
    Instance ID List
    IDs of virtual machines that the middleware is associated with.
    (Optional) Use commas (,) to separate multiple values. A maximum of 50 values are supported.
    Description of the middleware.
  7. Click Upload File to add the completed excel file.
    Wait until the table is imported. You can view the imported resources on the resource management page.
    Figure 1 Importing IDC Resources
    Figure 2 Viewing imported resources
Modifying IDC Resources
  1. Log in to COC.
  3. In the cloud vendor list on the left, click On-premises IDCs to view the IDC resources.
  4. Select the resource type to be modified.
    Physical machine is selected by default.
  5. Locate the resource you want to modify and click Modify in the Operation column.
    Figure 3 Modifying IDC Resources
  6. Modify the IDC resource information based on service requirements.
    Table 4 Physical machine parameters
    Example Value
    Name
    Test devices
    SN
    Serial number of the device.
    Private IP
    192.168.1.1
    Type
    Laptop
    UniAgent ID
    (Optional) Unique ID of UniAgent.
    Manufacturer
    Huawei
    OS
    OS from the drop-down list.
    Linux
    (Optional) Description of the device.
    Table 5 Virtual machine parameters
    Example Value
    Name
    Test devices
    Private IP
    192.168.1.1
    OS
    Select an OS from the drop-down list.
    Linux
    UniAgent ID
    ECS ID
    (Optional) Unique ID generated by OpenStack.
    Table 6 Middleware parameters
    Example Value
    Name
    Middleware name. This parameter cannot be changed.
    Test devices
    Type
    Middleware type, for example, MySQL. The parameter cannot be modified.
    MySQL
    Version
    Middleware version.
    V1.1
    Port
    Middleware port number.
    8000
    VM ID List
    (Optional) In the resource list, you can select a maximum of 50 virtual machines.
  7. Click OK. The IDC resource is modified.
Deleting IDC Resources
Deleting IDC resources only deletes the management information from COC. IDC resources are not directly deleted.
  1. Log in to COC.
  4. Select the resource type to be deleted.
  5. Locate the resource you want to delete and click Delete in the Operation column.
  6. Click OK. The IDC resource is deleted.
    After the resource is deleted, it will no longer be displayed in the resource list, and you cannot perform unified O&M operations on it in COC.
