- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Application and Resource Management/
Viewing Resource Topologies
You can view resource topologies.
View resource topologies on COC.
Precautions
Currently, only the topologies of instances of Elastic Cloud Servers (ECS), MapReduce Services (MRS) instance, Bare Metal Server (BMS), and Cloud Container Engine (CCE) can be viewed.
- Log in to COC.
- In the navigation pane on the left, choose Resources > Application and Resource Management. On the displayed Resources tab page, above the resource list, select the instances whose resource topology you want to check and click View Topology in the Operation column.
Figure 1 Viewing resource topologies
- On the displayed resource topology page, view the topology relationships between the selected resource and other resources.
Figure 2 Topology relationship
Parent topic: Resource Management
