Updated on 2026-06-16 GMT+08:00
Configuring a QUIC Listener for a LoadBalancer Service
Quick UDP Internet Connection (QUIC) is a high-performance, UDP-based transport protocol designed for low latency and to eliminate head-of-line blocking. Its strong performance helps reduce network lag and video stuttering, enhances overall network experience, and ensures secure data transmission. CCE supports QUIC for LoadBalancer Services. This section describes how to enable QUIC and access a Service using an Nginx application.
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.28: v1.28.15-r80 or later
    • v1.29: v1.29.15-r40 or later
    • v1.30: v1.30.14-r40 or later
    • v1.31: v1.31.14-r0 or later
    • v1.32: v1.32.9-r0 or later
    • v1.33: v1.33.7-r0 or later
    • v1.34: v1.34.2-r0 or later
    • Other clusters of later versions
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • You can obtain a trusted certificate from a certificate provider. For details, see Purchasing an SSL Certificate.
Notes and Constraints
  • QUIC listeners can be added only to dedicated load balancers of the application or network & application load balancing type.
  • QUIC listeners can only be associated with HTTP/HTTPS backend server groups.
  • The backend server group associated with a QUIC listener does not support the source IP hash algorithm.
  • QUIC listeners do not support the following HTTP headers:
    • X-Forwarded-For-Port: Rewrite this header to transfer the client port.
    • X-Real-IP: Rewrite this header to transfer the client IP address.
  • QUIC listeners cannot route requests based on CIDR blocks.
  • QUIC listeners do not support two-way authentication.
  • QUIC listeners do not support security policies.
A single Service can include multiple listeners that use different load balancer frontend protocols. When a listener is created, any unsupported configuration attributes are automatically ignored. It is advised to configure the same load balancer frontend protocol for all listeners within the same Service.
Step 1: Deploy a Sample Application
This section uses a Nginx Deployment as an example.
  2. In the navigation pane, choose Workloads. In the upper right corner, click Create Workload.
  3. In the Basic Info area, enter the workload name. In this example, the workload name is nginx. Retain the default settings for other parameters.
  4. In Container Information under Container Settings, specify the image name and tag. Retain the default settings for other parameters.
    Example
    Image Name
    Click Select Image. In the displayed dialog box, click Open Source Images under SWR Shared Edition, search for nginx, select it, and click OK.
    Image Tag
    Select the latest image tag.
  5. Retain the default settings for other parameters and click Create Workload.
Step 2: Create a LoadBalancer Service and Configure QUIC
You can use either of the following ways.
In this section, the sample certificate is cert-test. Replace it with the actual one.
  2. In the navigation pane, choose Services & Ingresses. In the upper right corner, click Create Service.
    In this example, only the mandatory parameters for configuring QUIC are listed. Retain the default settings for other parameters. For details, see Using the CCE Console (New Version).
  3. Configure basic parameters.
    Example
    Service Type
    Select LoadBalancer.
    None
    Service Name
    Enter a name, which can be the same as the workload name.
    nginx
    Namespace
    Select the namespace that the workload belongs to.
    default
    Selector
    Add the key and value of a pod label. The Service will be associated with the workload pods based on the label and direct traffic to the pods with this label.
    You can also click Reference Workload Label to use the label of an existing workload. In the dialog box displayed, select a workload and click OK.
    app:nginx
  4. Configure load balancer parameters.
    Example Value
    Load Balancer
    Select a load balance type and how the load balancer will be created. To enable QUIC on the listener port of a dedicated load balancer, the type of the load balancer must be Application (HTTP/HTTPS) or Network (TCP/UDP/TLS) & Application (HTTP/HTTPS).
    • Use existing: Only the load balancers in the same VPC as the cluster can be selected. If no load balancer is available, click Create Load Balancer to create one on the ELB console.
    • Auto create: The load balancer will be created in the VPC that the cluster belongs to. For details, see Table 1.
    An existing Dedicated load balancer of the Network (TCP/UDP/TLS) & Application (HTTP/HTTPS) type
  5. Configure access parameters.
    Example Value
    Service Affinity
    Whether to route external traffic to a local node or a cluster-wide endpoint. For details, see Service Affinity (externalTrafficPolicy).
    • Cluster-level: The IP addresses and ports of all nodes in a cluster can access the workload associated with the Service. However, accessing the Service may result in performance deterioration due to route redirection, and the client's source IP address may not be obtainable.
    • Node-level: Only the IP address and port of the node where the workload is located can access the workload associated with the Service. Accessing the Service will not result in a performance deterioration due to route redirection, and the client's source IP address can be obtained.
    Cluster-level
    Backend Routing Policy
    • Global: All ports use the same backend routing policy. For details about the backend routing policy parameters, see Table 1.
      CAUTION:
      When multiple ports are added, and some of them use different frontend protocols, the global backend routing policy cannot be applied across all protocols simultaneously. For any protocol to which the policy cannot be applied, CCE automatically falls back to the default configuration. For details about the mapping between the frontend and backend protocols of listeners and backend server groups, see Mapping Between Frontend and Backend Protocols for Load Balancing and Configuration Examples. Custom is recommended.
    • Custom: Each port can have a unique backend routing policy. You can configure the policy in Port > Backend Routing Policy.
    Custom
    Port
    • Protocol: the protocol used by the Service. According to the Kubernetes implementation, if a Service uses a load balancer with a non-UDP protocol, this parameter must be set to TCP and the corresponding listener frontend protocol must be selected. For details, see Protocols for Services.
    • Container Port: the port that the workload listens on. For example, Nginx uses port 80 by default.
    • Service Port: the port used by the Service.
      • Listen on a port: The port ranges from 1 to 65535.
      • Listening ports: not supported by QUIC listeners
    • Frontend Protocol: Set the protocol of the load balancer listener for establishing connections with clients. For a dedicated load balancer, to use QUIC, the type of the load balancer must be Application (HTTP/HTTPS).
    • Backend Routing Policy: If Backend Routing Policy is set to Custom, you can configure backend routing policies for ports that use different protocols. For details about the parameters, see Table 1.
    When a LoadBalancer Service is created, a random node port number (NodePort) is automatically generated.
    • Protocol: TCP
    • Container Port: 80
    • Service Port: 443
    • Frontend Protocol: QUIC
    Table 1 Parameters for configuring the backend routing policy
    Example
    Backend Protocol
    The service protocol used by the load balancer's backend server group. TCP, HTTP, HTTPS, TLS, QUIC, and UDP are supported. For details about the mapping between the frontend and backend protocols of listeners and backend server groups, see Mapping Between Frontend and Backend Protocols for Load Balancing and Configuration Examples.
    HTTP
    Load Balancing Algorithm
    Load balancers forward requests from clients to the corresponding backend servers based on the configured traffic routing policies.
    • Weighted round robin: Requests are forwarded to different backend servers in turn based on the server weights you define in the target group.
    • Weighted least connections: Requests are forwarded to the backend server with the smallest connections-to-weight ratio.
    • Source IP hash: Requests from the same source IP address are forwarded to the same backend server by hashing the source IP address.
  6. Configure QUIC listener parameters. Retain the default settings for other parameters.
    Constraint
    Example Value
    Server Certificate
    Select a server certificate. If no certificate is available, create one on the ELB console. For details, see Adding a Certificate.
    In this example, set Frontend Protocol to QUIC.
    cert-test
  7. Click Create.
If a Service uses the QUIC protocol, it is important to take note of the following configuration requirements:
  • The load balancer must be a dedicated one and the type must be Application or Network & Application.
  • The QUIC port in kubernetes.io/elb.protocol-port must match the TCP port in spec.ports. In this example, port 443 is used by the QUIC protocol.
In this example, an existing dedicated load balancer is used. The configuration example is as follows:
apiVersion: v1
kind: Service
  annotations:
    kubernetes.io/elb.id: <your_elb_id>    # In this example, an existing dedicated load balancer is used. Replace its ID with the ID of your dedicated load balancer.
    kubernetes.io/elb.class: performance  # A dedicated load balancer
    kubernetes.io/elb.protocol-port: quic:443  # QUIC and port, which must match the TCP port in spec.ports
    kubernetes.io/elb.cert-id: 17e3b4f4bc40471c86741dc3aa211379 # Certificate ID of the ELB service
  labels:
    app: nginx
  namespace: default
  ports:
  - name: cce-service-0
    port: 443
    protocol: TCP
    targetPort: 80
  selector:
    app: nginx
    version: v1
  sessionAffinity: None
  type: LoadBalancer
Table 2 Key parameters
Type
String
If a Service is TLS/HTTP/HTTPS/QUIC-compliant, configure the protocol and port in the format of protocol:port.
Where,
  • protocol: the protocol used by the listener port. The value can be tls, http, or https.
  • port: Service port specified by spec.ports[].port.
In this example, port 443 is used by the QUIC protocol. So, the parameter value is quic:443.
Step 3: Access the Service
For web applications, the client that supports QUIC connections must support HTTP/3. For details, see HTTP3 (and QUIC).
  1. Configure a client to support HTTP/3. curl on Windows is used as an example. Run the command below to check whether curl supports HTTP/3. You can download the latest version of curl from Releases and Downloads.
  2. Copy the EIP and port of the load balancer and use curl to access the address. If the access is normal, the client and backend server can communicate with each other using HTTP/3 through QUIC.
