Help Center/ Cloud Container Engine/ User Guide/ Networking/ Services/ LoadBalancer/ Network and Backend Configuration/ Configuring an HTTP/HTTPS Header for a LoadBalancer Service
Updated on 2026-09-29 GMT+08:00
HTTP headers are a list of strings sent and received by both the client and server on every HTTP request and response. This section describes HTTP headers supported by HTTP and HTTPS listeners.
  • HTTP/HTTPS headers rely on ELB. Before using HTTP/HTTPS headers in a Service, check whether HTTP/HTTPS headers are supported in the current region. For details, see HTTP/HTTPS Headers.
  • After HTTP or HTTPS is configured, if you delete the HTTP or HTTPS configuration on the CCE console or delete the target annotation from the YAML file, the configuration on the ELB will be retained.
Table 1 Headers
Header
Feature
Supported Cluster Version
X-Forwarded-Port
Transfer Listener Port Number
If this option is enabled, ELB inserts the listener port number into the X-Forwarded-Port header of requests forwarded to backend servers.
v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later
X-Forwarded-For-Port
Transfer Port Number in the Request
If this option is enabled, the client port number is transmitted to backend servers via the X-Forwarded-For-Port header.
X-Forwarded-Host
Rewrite X-Forwarded-Host
If this option is enabled, the Host field from the client request header is rewritten into the X-Forwarded-Host header and passed to backend servers.
X-Real-IP
Rewrite X-Real-IP
If this option is enabled, the client source IP address is rewritten into the X-Real-IP header and passed to backend servers.
v1.25.16-r30, v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, v1.32.1-r0, or later
X-Forwarded-ELB-IP
Transfer Load Balancer EIP
If this option is enabled, ELB passes the load balancer's EIP to backend servers via the HTTP request header. This option is available only for dedicated load balancers with HTTP or HTTPS listeners.
v1.30.14-r100, v1.31.14-r60, v1.32.13-r30, v1.33.12-r10, v1.34.8-r10, v1.35.5-r10, v1.36.2-r0, or later
X-Forwarded-ELB-ID
Transfer Load Balancer ID
If this option is enabled, ELB passes the load balancer's ID to backend servers via the HTTP request header. This option is available only for dedicated load balancers with HTTP or HTTPS listeners.
X-Forwarded-Proto
Transfer Listener Protocol
If this option is enabled, ELB passes the load balancer's listener protocol to backend servers via the HTTP request header. This option is available only for dedicated load balancers with HTTP or HTTPS listeners.
X-Forwarded-TLS-Certificate-ID
Transfer Certificate ID
If this option is enabled, ELB passes the load balancer's certificate ID to backend servers via the HTTP request header. This option is available only for dedicated load balancers with HTTPS listeners.
X-Forwarded-TLS-Protocol
Transfer TLS Protocol
If this option is enabled, ELB passes the load balancer's TLS protocol to backend servers via the HTTP request header. This option is available only for dedicated load balancers with HTTPS listeners.
X-Forwarded-TLS-Cipher
Transfer Cipher Suite
If this option is enabled, ELB passes the load balancer's cipher suite to backend servers via the HTTP request header. This option is available only for dedicated load balancers with HTTPS listeners.
  • A Kubernetes cluster is available and the cluster version meets the requirements in Table 1.
Creating a LoadBalancer Service and Configuring an HTTP/HTTPS Header
Use one of the following methods.
  2. In the navigation pane, choose Services and Ingresses. In the upper right corner, click Create Service.
    In this example, only mandatory parameters for configuring SNI are listed. Retain the default settings for other parameters. For details, see Using the CCE Console.
  3. Configure basic parameters.
    Example
    Service Type
    Select LoadBalancer.
    None
    Service Name
    Enter a name, which can be the same as the workload name.
    nginx
    Namespace
    Select the namespace that the workload belongs to.
    default
    Selector
    Add the key and value of a pod label. The Service will be associated with the workload pods based on the label and direct traffic to the pods with this label.
    You can also click Reference Workload Label to use the label of an existing workload. In the dialog box displayed, select a workload and click OK.
    app:nginx
  4. Configure load balancer parameters.
    Example
    Load Balancer
    Select a load balance type and how the load balancer will be created. To enable HTTP/HTTPS on the listener port of a dedicated load balancer, the type of the load balancer must be Application (HTTP/HTTPS) or Network (TCP/UDP/TLS) & Application (HTTP/HTTPS).
    • Use existing: Only the load balancers in the same VPC as the cluster can be selected. If no load balancer is available, click Create Load Balancer to create one on the ELB console.
    • Auto create: The load balancer will be created in the VPC that the cluster belongs to. For details, see Table 1.
    An existing Dedicated load balancer of the Network (TCP/UDP/TLS) & Application (HTTP/HTTPS) type
  5. Configure access parameters.
    Example
    Service Affinity
    Whether to route external traffic to a local node or a cluster-wide endpoint. For details, see Service Affinity (externalTrafficPolicy).
    • Cluster-level: The IP addresses and ports of all nodes in a cluster can access the workload associated with the Service. However, accessing the Service may result in performance deterioration due to route redirection, and the client's source IP address may not be obtainable.
    • Node-level: Only the IP address and port of the node where the workload is located can access the workload associated with the Service. Accessing the Service will not result in performance deterioration due to route redirection, and the client's source IP address can be obtained.
    Cluster-level
    Port
    • Protocol: the protocol used by the Service. According to the Kubernetes implementation, if a Service uses a load balancer with a non-UDP protocol, this parameter must be set to TCP and the corresponding listener frontend protocol must be selected. For details, see Protocols for Services.
    • Container Port: the port that the workload listens on. For example, Nginx uses port 80 by default.
    • Service Port: the port used by the Service.
      • Listen on a port: The port ranges from 1 to 65535.
      • Listen on ports: ELB allows you to create listeners that listen on ports within specified ranges. Each listener can support up to 10 non-overlapping port ranges.
        To configure port ranges for load balancer listeners, ensure the following conditions are met:
        • The cluster version must be v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later.
        • A dedicated load balancer must be used with TCP/UDP/TLS selected.
        • This function requires ELB. Before using this function, check whether ELB supports full-port listening and forwarding for layer-4 protocols in the current region.
    • Frontend Protocol: specifies the protocol for the load balancer listener used to establish connections with clients. When a dedicated load balancer is selected, HTTP/HTTPS can be configured only when Application (HTTP/HTTPS) is selected and TLS can be configured only when Network (TCP/UDP/TLS) is selected.
    When a LoadBalancer Service is created, a random node port number (NodePort) is automatically generated.
    • Protocol: TCP
    • Container Port: 80
    • Service Port: 80
    • Frontend Protocol: HTTP
  6. Configure listener parameters.
    Constraint
    Example
    If this option is enabled, the listener port number is transmitted to backend servers via the HTTP header.
    This parameter is available only if HTTP or HTTPS is used as the frontend protocol of a dedicated load balancer listener.
    Enable
    If this option is enabled, the client source port is transmitted to backend servers via the HTTP header.
    Enable
    Enable
    Rewrite X-Real-IP
    Enable
    This parameter can be configured only when HTTP or HTTPS is used with a dedicated load balancer.
    Enable
    Enable
    Enable
    Enable
    Enable
    Enable
  7. Click Create.
This section uses an existing load balancer as an example. An example YAML file of a Service with HTTP/HTTPS header enabled is as follows:
apiVersion: v1
kind: Service
  labels:
    app: nginx
  namespace: default
  annotations:
    kubernetes.io/elb.class: performance                              # Load balancer type, which can only be performance (dedicated load balancer)
    kubernetes.io/elb.id: 35cb350b-23e6-4551-ac77-10d5298f5204        # ID of an existing load balancer
    kubernetes.io/elb.protocol-port: https:443                          # HTTPS port 443 is used.
    kubernetes.io/elb.x-forwarded-port: 'true'                       # Obtain the listener port number.
    kubernetes.io/elb.x-forwarded-for-port: 'true'                   # Obtain the client port number for requests.
    kubernetes.io/elb.x-forwarded-host: 'true'                       # Rewrite X-Forwarded-Host.
    kubernetes.io/elb.x-real-ip: 'true'                              # Rewrite X-Real-IP.
    kubernetes.io/elb.x-forwarded-proto: 'true'              # Forward the load balancer's listener protocol to backend servers.
    kubernetes.io/elb.x-forwarded-elb-ip: 'true'             # Forward the load balancer's EIP to backend servers.
    kubernetes.io/elb.x-forwarded-elb-id: 'true'             # Forward the load balancer's ID to backend servers.
    kubernetes.io/elb.x-forwarded-tls-certificate-id: 'true' # Forward the load balancer's certificate ID to backend servers.
    kubernetes.io/elb.x-forwarded-tls-protocol: 'true'       # Forward the load balancer's TLS version to backend servers.
    kubernetes.io/elb.x-forwarded-tls-cipher: 'true'         # Forward the load balancer's cipher suite to backend servers.
    kubernetes.io/elb.tls-certificate-ids: 6cfb43c9de1a41a18478b868e3******       # HTTPS listener server certificate
  selector:
    app: nginx
  externalTrafficPolicy: Cluster
  ports:
    - name: cce-service-0
      targetPort: 80
      nodePort: 0
      port: 80
      protocol: TCP
  type: LoadBalancer
  loadBalancerIP: **.**.**.**    # IP address of the load balancer
Table 2 Key parameters
Type
String
A load balancer can obtain the port number of a listener using X-Forwarded-Port and transmit the port number to the packets of the backend server.
  • true: Enable the function of obtaining a listener port number.
  • false: Disable the function of obtaining a listener port number.
String
A load balancer can obtain a client port number for requests using X-Forwarded-For-Port and transmit the port number to the packets of the backend server.
  • true: Enable the function of obtaining a client port number for requests.
  • false: Disable the function of obtaining a client port number for requests.
String
  • true: Enable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header will be rewritten using the Host header of the client request and transmitted to backend servers.
  • false: Disable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header of the client will be transmitted to backend servers.
String
  • true: Enable the function of rewriting X-Real-IP. The source IP address of the client will be written into the X-Real-IP header and transmitted to the backend servers.
  • false: Disable the function of rewriting X-Real-IP. The X-Real-IP header of the client will be transmitted to the backend servers.
String
Enables the load balancer to pass the listener's EIP to backend servers via the x-forwarded-elb-ip header field in forwarded requests. Only HTTP and HTTPS are supported.
● true: Enable
● false (default): Disable
String
Enables the load balancer to pass its ELB ID to backend servers via the x-forwarded-elb-id header field in forwarded requests. Only HTTP and HTTPS are supported.
● true: Enable
String
Enables the load balancer to pass the listener protocol to backend servers via the x-forwarded-proto header field in forwarded requests. Only HTTP and HTTPS are supported.
● true (default): Enable
● false: Disable
String
Enables the load balancer to pass the TLS certificate ID to backend servers via the x-forwarded-tls-certificate-id header field in forwarded requests. Only HTTPS is supported.
● true: Enable
String
Enables the load balancer to pass the algorithm protocol to backend servers via the x-forwarded-tls-protocol header field in forwarded requests. Only HTTPS is supported.
● false: Disable
String
Enables the load balancer to pass the TLS cipher suite to backend servers via the x-forwarded-tls-cipher header field in forwarded requests. Only HTTPS is supported.
● true: Enable
Verifying Configuration
  2. In the navigation pane, choose Services and Ingresses. Locate the row containing the created Service and click the load balancer name to go to the ELB console.
  3. Switch to the Listeners tab, click the listener name of the created port, and check whether options are enabled.
