Prometheus Agent View
Prometheus Agent is a lightweight version of Prometheus Server. It scrapes the metrics for all hosts and components. The metrics are then reported to and stored on AOM or a third-party monitoring platform. The Prometheus Agent view displays some built-in metrics provided by Prometheus, which can be used to monitor and measure system performance and status.
Metric Description
You can view Prometheus Agent metrics in the following table.
         Metric  |
         Unit  |
         Description  |
         CPU Usage  |
         Average CPU usage of pods.  |
         Memory Usage  |
         Average memory usage of pods.  |
         Remote Write Rate  |
         byte/s  |
         The number of bytes remotely written per second.  |
         Average Remote Write Duration  |
         second  |
         Average time consumed by remote writes.  |
         Bytes Pending for Remote Write  |
         byte  |
         The number of pending bytes during a remote write.  |
         Packets Discarded for Remote Write per Second  |
         N/A  |
         The number of packets discarded per second during a remote write.  |
         Failed Remote Write Requests per Second  |
         N/A  |
         The number of failed remote write requests per second.  |
         Percentage of Failed Remote Write Requests  |
         Percentage of failed remote write requests.  |
         Remote Write Retries per Second  |
         N/A  |
         The number of retries of the remote write per second.  |
         Scrapers  |
         N/A  |
         The number of scrapers.  |
         Collections per Second  |
         N/A  |
         Collections per second.  |
         Average Collection Duration  |
         second  |
         Average collection duration.  |
         Failed Reads During Collection per Second  |
         N/A  |
         The number of read errors during scrapes per second.  |
         Failed Writes During Collection per Second  |
         N/A  |
         The number of write errors during scrapes per second.  |
         Collections with Size Exceeding the Threshold per Second  |
         N/A  |
         Collections with size exceeding the threshold per second.  |
         Read Rate of Sending Queue  |
         byte/s  |
         The number of bytes read by a sending queue per second.  |
         Write Rate of Sending Queue  |
         byte/s  |
         The number of bytes written to a sending queue per second.  |
         Pending Size of Sending Queue  |
         byte  |
         The number of bytes suspended in a sending queue.  |
         Blocks Read per Second  |
         N/A  |
         The number of blocks read by a sending queue per second.  |
         Blocks Written per Second  |
         N/A  |
         The number of blocks written to a sending queue per second.  |
         Discarded Blocks per Second  |
         N/A  |
         The number of dropped blocks in a sending queue per second.  |
Metric List
          Metric  |
          Type  |
          Description  |
          container_cpu_usage_seconds_total  |
          Gauge  |
          Cumulative CPU time consumed in seconds.  |
          container_memory_working_set_bytes  |
          Gauge  |
          Current working set in bytes.  |
          vmagent_remotewrite_bytes_sent_total  |
          Counter  |
          Total number of bytes remotely written by Prometheus Agent.  |
          vmagent_remotewrite_duration_seconds_sum  |
          Summary  |
          Time consumed by a Prometheus Agent remote write.  |
          vmagent_remotewrite_pending_data_bytes  |
          Gauge  |
          The number of pending bytes during a Prometheus Agent remote write.  |
          vmagent_remotewrite_packets_dropped_total  |
          Counter  |
          Total number of dropped packets during a Prometheus Agent remote write.  |
          vmagent_remotewrite_requests_total  |
          Counter  |
          Total number of Prometheus Agent remote write requests.  |
          vmagent_remotewrite_retries_count_total  |
          Counter  |
          Total number of remote write retries of Prometheus Agent.  |
          vm_promscrape_active_scrapers  |
          Gauge  |
          The number of collected shards.  |
          vm_promscrape_scrapes_total  |
          Counter  |
          The number of scrapes.  |
          vm_promscrape_scrape_duration_seconds_sum  |
          Summary  |
          Time required for the vmagent to collect metrics.  |
          vm_promscrape_conn_read_errors_total  |
          Counter  |
          The number of read errors during scrapes.  |
          vm_promscrape_conn_write_errors_total  |
          Counter  |
          The number of write errors during scrapes.  |
          vm_promscrape_max_scrape_size_exceeded_errors_total  |
          Counter  |
          The number of failed scrapes due to the exceeded response size.  |
          vm_persistentqueue_bytes_read_total  |
          Counter  |
          The number of bytes read by a send queue.  |
          vm_persistentqueue_bytes_written_total  |
          Counter  |
          The number of bytes written to a send queue.  |
          vm_persistentqueue_bytes_pending  |
          Gauge  |
          The number of pending bytes in a send queue.  |
          vm_persistentqueue_blocks_read_total  |
          Counter  |
          The number of blocks read by a send queue.  |
          vm_persistentqueue_blocks_written_total  |
          Counter  |
          The number of blocks written to a send queue.  |
          vm_persistentqueue_blocks_dropped_total  |
          Counter  |
          The number of dropped blocks in a send queue.  |
