Updated on 2025-07-17 GMT+08:00
Configuring a Slow Start for a LoadBalancer Ingress
With slow start configured, a load balancer linearly increases the proportion of requests to backend server pods. When the slow start duration elapses, the load balancer sends full share of requests to backend server pods and exits the slow start mode. Slow start gives applications time to warm up and respond to requests with optimal performance.
After a slow start is configured, if you delete the target annotation from the YAML file, slow start will not be enabled.
Notes and Constraints
  • Slow start is only available for HTTP, HTTPS, and gRPC backend server groups (pods) of dedicated load balancers.
  • Slow start takes effect only when the weighted round robin algorithm is used.
  • Slow start takes effect only for new backend server pods.
  • After the slow start duration elapses, backend servers will not enter the slow start mode again.
  • Slow start takes effect when health check is enabled and backend server pods are running properly.
  • If health check is disabled, slow start takes effect immediately.
  • With slow start configured for an ingress, all forwarding policies of the ingress take effect.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.port: '80'
        kubernetes.io/elb.id: <your_elb_id>  # Replace it with the ID of your existing load balancer.
        kubernetes.io/elb.class: performance
        kubernetes.io/elb.slowstart: '30' #Configure a slow start.
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    name: <your_service_name>  # Replace it with the name of your target Service.
                    port:
                      number: 80             # Replace 80 with the port number of your target Service.
                property:
      ingressClassName: cce
    Table 1 Parameters for configuring a slow start
    Mandatory
    Type
    No
    String
    Specifies whether to enable slow start. After you enable it, the load balancer linearly increases the proportion of requests to backend server pods in this mode. When the slow start duration elapses, the load balancer sends full share of requests to backend server pods and exits the slow start mode.
    Clusters later than v1.23 support this field.
    The slow start duration ranges from 30 to 1200.
    Duration of slow start, in seconds.
    • Grayscale release applies only to dedicated load balancers.
    • This parameter is valid only when the allocation policy of the target Service is weighted round robin (WRR) and sticky session is disabled.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     80      10s
