Configuring URL Redirection for a LoadBalancer Ingress
Ingresses can redirect specific access requests to a specified URL. The following is an example YAML file for configuring an ingress redirection rule. In this example, the request for accessing example.com is redirected to example.com/testa with a 301 status code.
- A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
- v1.23: v1.23.14-r0 or later
- v1.25: v1.25.9-r0 or later
- v1.27: v1.27.6-r0 or later
- v1.28: v1.28.4-r0 or later
- Other clusters of later versions
- An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
- A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Notes and Constraints
- This feature is only available when dedicated load balancers are used.
- This feature relies on the ELB advanced forwarding policies. Once enabled, the priority is not determined by the domain name or path matching. You can customize the forwarding policy priority as needed. For details about the forwarding policy priority, see Forwarding Policy Priorities of LoadBalancer Ingresses.
Configuring a Rule for Redirecting an Ingress to a URL
You can configure a rule for redirecting an ingress to a URL using either the CCE console or kubectl.
- Choose Services & Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
- Configure ingress parameters.
This example explains only key parameters for configuring URL redirection. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
Table 1 Key parameters Parameter
Example
Name
Enter an ingress name.
ingress-test
Load Balancer
Select a load balancer to be associated with the ingress or automatically create a load balancer. In this example, only dedicated load balancers are supported.
Dedicated
Listener
- Frontend Protocol: HTTP and HTTPS are available.
- External Port: specifies the port of the load balancer listener.
- External Port: 80
Forwarding Policy
- Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
- Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
- Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
- Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
- Destination Service Port: Select the access port of the destination Service.
- Actions
- Operation: Select Redirect to URL. When an access request meets the forwarding policy, the request will be redirected to a specified URL, and a specific status code will be returned.
- URL: A URL starting with http:// or https:// is valid.
HTTP routes can be redirected to HTTP or HTTPS routes. HTTPS routes can be redirected only to HTTPS routes.
- StatusCode: The return code can be 301, 302, 303, 307, or 308.
- Domain Name: example.com
- Path Matching Rule: Prefix match
- Path: /
- Destination Service: nginx
- Destination Service Port: 80
- Actions:
- Operation: Redirect to URL
- URL: https://example.com/testa
- StatusCode: 301
Figure 1 Configuring a rule for redirecting an ingress to a URL
- Click OK.
An ingress can be redirected to a URL using annotations. Example:
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
An example YAML file of an ingress associated with an existing load balancer is as follows:
apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: test-redirect-url namespace: default annotations: kubernetes.io/elb.id: df76342f-e898-402a-bac8-bde5bf974da8 kubernetes.io/elb.class: performance kubernetes.io/elb.port: '80' kubernetes.io/elb.redirect-url: https://example.com/testa # Information about the redirection to a URL kubernetes.io/elb.redirect-url-code: '301' # Code returned after requests are redirected to a URL spec: rules: - host: "example.com" http: paths: - path: / backend: service: name: test-service port: number: 80 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceTable 2 Key parameters Parameter
Mandatory
Type
Yes
String
URL for redirection
Format:
- HTTPS ingresses: valid URLs starting with https://, for example, https://example.com/
- HTTP ingresses: valid URLs starting with http:// or https://, for example, https://example.com/
Parameter: This configuration takes effect on all forwarding rules of a single ingress. After the configuration is deleted, the target URL redirection rule will be automatically cleared.
Either this annotation or the annotation of a grayscale release can be configured.
No
String
Code returned after an ingress is redirected to a URL.
Format: The return code can be 301, 302, 303, 307, or 308.
Parameter: The default value is 301.
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress/test-redirect-url created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE test-redirect-url cce example.com 121.**.**.** 80 10s
- Use curl to verify the redirection, where ${ELB_IP} is the IP address accessed by the target ingress.
curl -I -H "Host:example.com" ${ELB_IP}The access path will be redirected to example.com/testa.
HTTP/1.1 301 Moved Permanently Date: Thu, 07 Mar 2024 11:04:31 GMT Content-Type: text/html Content-Length: 134 Connection: keep-alive Location: https://example.com/testa Server: elb
