Deprecated Kubernetes APIs
Check Items
Due to the limited time range of audit logs, this check item is only an auxiliary method. APIs to be deprecated may have been used in the cluster, but their usage is not included in the audit logs of the past day. Check the API usage carefully.
Check Description
Based on the check result, it is detected that your cluster calls a deprecated API of the target cluster version using kubectl or other applications. You can rectify the fault before the upgrade. Otherwise, the API will be intercepted by kube-apiserver after the upgrade. For details about each deprecated API, see Deprecated APIs.
Cases
Case 1
Ingresses of the extensions/v1beta1 and networking.k8s.io/v1beta1 APIs are deprecated in Kubernetes v1.22. If you upgrade a cluster from v1.19 or v1.21 to v1.23, existing resources are not affected, but the v1beta1 API may be intercepted in the creation and editing scenarios.
For details about the YAML configuration structure changes, see Using kubectl to Create a LoadBalancer Ingress.
Case 2
The scanning result indicates that the user agent's coredns client is accessing the deprecated or to-be-deprecated discovery.k8s.io/v1beta1 Kubernetes API (specifically the /apis/discovery.k8s.io/v1beta1/endpointslices path). To prevent domain name resolution issues during the cluster upgrade, you must manually restart the CoreDNS pods before proceeding. For details, see How Can I Address the Issue of CoreDNS Using Deprecated APIs?
Case 3
In v1.28, the Kubernetes community deprecated allowWatchBookmarks=true in the events API (support was restored in v1.29). If your components use this parameter in watch requests for events, remove it before upgrading to v1.28.
