Updated on 2026-09-21 GMT+08:00
(kubectl) Creating a PV from an Existing SFS Turbo File System
CCE allows you to use an existing SFS Turbo file system to create a PersistentVolume (PV). After the creation is successful, you can create a PersistentVolumeClaim (PVC) and bind it to the PV.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Log in to the SFS console, create a file system, and record the file system ID, shared path, and capacity.
  2. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  3. Create two YAML files for creating the PV and PVC. Assume that the file names are pv-efs-example.yaml and pvc-efs-example.yaml.
    touch pv-efs-example.yaml pvc-efs-example.yaml
    • Example YAML file for the PV:
      apiVersion: v1
      kind: PersistentVolume
        annotations:
          pv.kubernetes.io/provisioned-by: flexvolume-huawei.com/fuxiefs
        accessModes:
        - ReadWriteMany
        capacity:
          storage: 100Gi
        claimRef:
          apiVersion: v1
          kind: PersistentVolumeClaim
          namespace: default
        flexVolume:
          driver: huawei.com/fuxiefs
          fsType: efs
          options:
            deviceMountPath: <your_deviceMountPath>  # Shared storage path of your SFS Turbo file.
            fsType: efs
            volumeID: 8962a2a2-a583-4b7f-bb74-fe76712d8414
        persistentVolumeReclaimPolicy: Delete
        storageClassName: efs-standard
      Table 1 Key parameters
      driver
      Storage driver used to mount the volume. Set it to huawei.com/fuxiefs.
      deviceMountPath
      Shared path of the SFS Turbo volume.
      volumeID
      SFS Turbo volume ID.
      To obtain the ID, log in to the CCE console, choose Resource Management > Storage, click the PVC name in the SFS Turbo tab page, and copy the PVC ID on the PVC details page.
      storage
      File system size.
      storageClassName
      Volume type supported by SFS Turbo. The value can be efs-standard and efs-performance. Currently, SFS Turbo does not support dynamic creation; therefore, this parameter is not used for now.
      spec.claimRef.apiVersion
      The value is fixed at v1.
      spec.claimRef.kind
      The value is fixed at PersistentVolumeClaim.
      spec.claimRef.name
      The value is the same as the name of the PVC created in the next step.
      spec.claimRef.namespace
      The value is the same as the namespace of the PVC created in the next step.
    • Example YAML file for the PVC:
      apiVersion: v1
        annotations:
          volume.beta.kubernetes.io/storage-class: efs-standard
          volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxiefs
        namespace: default
        accessModes:
        - ReadWriteMany
        resources:
          requests:
            storage: 100Gi
        volumeName: pv-efs-example
      Table 2 Key parameters
      Read/write mode supported by SFS Turbo. The value can be efs-standard or efs-performance. The value must be the same as that of the existing PV.
      The field must be set to flexvolume-huawei.com/fuxiefs.
      storage
      Storage capacity, in the unit of Gi. The value must be the same as the storage size of the existing PV.
      volumeName
      Name of the PV.
    The VPC to which the SFS Turbo file system belongs must be the same as the VPC of the ECS VM planned for the workload. Ports 111, 445, 2049, 2051, and 20048 must be enabled in the security groups.
  4. Create the PV.
    kubectl create -f pv-efs-example.yaml
  5. Create the PVC.
    kubectl create -f pvc-efs-example.yaml
