(kubectl) Creating a StatefulSet Mounted with an SFS Volume
CCE allows you to use an existing SFS volume to create a StatefulSet through a PersistentVolumeClaim (PVC).
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
- Create an SFS volume by referring to Automatically Creating an SFS Volume Through kubectl and record the volume name.
- Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file for creating the workload. Assume that the file name is sfs-statefulset-example.yaml.
touch sfs-statefulset-example.yaml
vi sfs-statefulset-example.yaml
Example YAML:
apiVersion: apps/v1 kind: StatefulSet metadata: name: sfs-statefulset-example namespace: default spec: replicas: 2 selector: matchLabels: app: sfs-statefulset-example serviceName: qwqq template: metadata: annotations: metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]' pod.alpha.kubernetes.io/initialized: "true" labels: app: sfs-statefulset-example spec: affinity: {} containers: - image: nginx:latest name: container-0 volumeMounts: - mountPath: /tmp name: pvc-sfs-example imagePullSecrets: - name: default-secret volumes: - name: pvc-sfs-example persistentVolumeClaim: claimName: cce-sfs-demoTable 1 Key parameters Parent Parameter
spec
replicas
Number of pods.
metadata
name
Name of the created workload.
spec.template.spec.containers
Image used by the workload.
spec.template.spec.containers.volumeMounts
mountPath
Mount path in the container.
spec
serviceName
Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
spec.template.spec.volumes.persistentVolumeClaim
claimName
Name of an existing PVC.
spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
- Create the StatefulSet.
kubectl create -f sfs-statefulset-example .yaml
