(kubectl) Creating a Deployment Mounted with an SFS Volume
After an SFS volume is created or imported to CCE, you can mount the volume to a workload.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
- Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
- Run the following commands to configure the sfs-deployment-example.yaml file, which is used to create a pod.
touch sfs-deployment-example.yaml
vi sfs-deployment-example.yaml
Example of mounting an SFS volume to a Deployment (PVC-based, shared volume):apiVersion: apps/v1 kind: Deployment metadata: name: sfs-deployment-example # Workload name namespace: default spec: replicas: 1 selector: matchLabels: app: sfs-deployment-example template: metadata: labels: app: sfs-deployment-example spec: containers: - image: nginx name: container-0 volumeMounts: - mountPath: /tmp # Mount path name: pvc-sfs-example imagePullSecrets: - name: default-secret restartPolicy: Always volumes: - name: pvc-sfs-example persistentVolumeClaim: claimName: pvc-sfs-auto-example # PVC nameTable 1 Key parameters Parent Parameter
metadata
name
Name of the pod to be created.
spec.template.spec.containers.volumeMounts
mountPath
Mount path in the container. In this example, the mount path is /tmp.
spec.template.spec.volumes.persistentVolumeClaim
claimName
Name of an existing PVC.
spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
Example of mounting an SFS volume to a StatefulSet (PVC template-based, dedicated volume):
Currently, SFS file systems are sold out and cannot be exclusively used by defining the PVC template.
Example YAML:apiVersion: apps/v1 kind: StatefulSet metadata: name: deploy-sfs-nfs-rw-in namespace: default labels: appgroup: '' spec: replicas: 2 selector: matchLabels: app: deploy-sfs-nfs-rw-in template: metadata: labels: app: deploy-sfs-nfs-rw-in spec: containers: - name: container-0 image: 'nginx:1.12-alpine-perl' volumeMounts: - name: bs-nfs-rw-mountoptionpvc mountPath: /aaa imagePullSecrets: - name: default-secret volumeClaimTemplates: - metadata: name: bs-nfs-rw-mountoptionpvc annotations: volume.beta.kubernetes.io/storage-class: nfs-rw volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxinfs spec: accessModes: - ReadWriteMany resources: requests: storage: 1Gi serviceName: wwwwTable 2 Key parameters Parent Parameter
metadata
name
Name of the created workload.
Image of the workload.
mountPath
spec
serviceName
Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
spec.template.spec.containers.volumeMounts.name and spec.volumeClaimTemplates.metadata.name must be consistent because they have a mapping relationship.
- Run the following command to create the pod:
kubectl create -f sfs-deployment-example.yaml
After the creation is complete, log in to the CCE console. In the navigation pane, choose Resource Management > Storage > SFS. Click the PVC name. On the PVC details page, you can view the binding relationship between SFS and PVC.
