Help Center/ Cloud Backup and Recovery/ User Guide/ Data Restoration/ Restoring from a Cloud Server Backup
Updated on 2026-11-26 GMT+08:00
If a disk on a server fails or server data is lost due to human error, you can use an existing backup to restore the original server.
You can also restore the backup to another server. For details, see How Do I Restore Data to a New Server?
The server is stopped before a data restoration, and automatically starts up after the restoration is complete. If you deselect Start the server immediately after restoration, you need to manually start the server after the restoration is complete.
  • A data disk backup cannot be restored to the system disk.
  • Data cannot be restored to servers in the Faulty state.
  • Concurrent data restoration is not supported.
  • Scheduled restoration is not supported.
  • A backup of an ECS created using an ISO image cannot be used to directly restore data. You can use the backup to create an image and then provision an ECS using the image.
  • An ongoing restoration task cannot be terminated.
  • Data cannot be restored for a cloud server that is being backed up.
  • When the backup status is Creating (available within the AZ), you can use the backup to restore data. Data can only be restored in the same AZ as the server. If the AZ is faulty, the restoration may fail.
  • When the backup status is Creating (available within the AZ) and the backup is being created or used to restore data, the backup cannot be used to create an image.
  • Disks are running properly on the server whose data needs to be restored.
  • The server has at least one available backup.
  1. Log in to the CBR console. Click in the upper left corner and select a region.
  2. Click the Backups tab. Locate the desired backup. For details, see Viewing a Backup.
  3. Click Restore Server in the Operation column, as shown in Figure 1.
    • The current server data will be overwritten by the data captured at the time of backup. The restoration cannot be undone.
    • Servers will be shut down during restoration. It is recommended that you perform restoration during off-peak hours.
    Figure 1 Restoring a server
  4. (Optional) Deselect Start the server immediately after restoration.
    If you do so, manually start the server after the restoration is complete.
  5. In the Destination Disk drop-down list, select the target disk to which the backup will be restored.
    If the number of disks to be restored is greater than the number of disks that were backed up, restoration may cause data inconsistency.
    For example, if the Oracle data is scattered across multiple disks and only some of the disks are restored, data may become inconsistent and the application may fail to start.
    • If the server has only one disk, the backup is restored to that disk by default.
    • If the server has multiple disks, the backup is restored to the original disks by default. You can also restore the backup to a different disk of at least the same size as the original disk.
  6. After confirming that the information is correct, enter YES. Click Yes and confirm that the restoration is successful.
    You can view the restoration status in the backup list. When the backup enters the Available state and no new restoration tasks fail, the restoration is successful. The data is restored to the state when that backup was created.
    For details about how to view failed restoration tasks, see Task Management.
    If you use a cloud server backup to restore a logical volume group, you need to attach the logical volume group again.
    If the restoration takes a long time, click the target backup name in the backup list. On the backup details page, check the value of Instant Restore Support. If the value is No, the current backup is not an enhanced backup. Therefore, the restoration takes a long time. You are advised to manually create a full backup for the resources. The new backup is an enhanced backup and can then be used to restore resources.
