Updated on 2026-07-09 GMT+08:00
Creating a Database Server Backup
Cloud server backup supports both crash-consistent and application-consistent backups. You can use it to back up ECSs running MySQL or SAP HANA databases, as application-consistent backups ensure transactional consistency by capturing in-memory data and pending I/O operations.
  • Application-consistent backup is currently not supported for cluster applications, such as, MySQL Cluster. It is supported only for applications on standalone servers.
  • To ensure services run normally, perform an application-consistent backup during off-peak hours (for example, at night or on weekends) to minimize the impact on services. If an application-consistent backup is performed during peak hours, the backup may fail or database services may be blocked.
  1. Log in to the CBR console. Click in the upper left corner and select a region.
  2. Create a vault for application-consistent backups by referring to "Purchasing a Server Backup Vault" in Creating a Cloud Server Backup. Select Enable for Application-Consistent Backup.
    Figure 1 Enabling application-consistent backup
  3. Associate the cloud servers with the created vault. Ensure that the Agent has been installed on the servers.
  4. Create a cloud server backup by referring to Creating a Cloud Server Backup.
    • If an application-consistent backup is created successfully, a blue letter "A" is displayed next to the backup name in the backup list.
    • If an application-consistent backup fails to be created, CBR automatically creates a cloud server backup instead and stores the backup in the vault, and a gray letter "A" is displayed next to the backup name in the backup list. You can view the failure cause in the Management Information area on the backup details page.
      Figure 2 Application-consistent backup status
  5. Return to the cloud server backup page as prompted. If the backup execution fails, rectify the fault based on the failure details shown on the page.
Follow-up Procedure
If data is lost due to virus attacks or database faults, you can restore the data by following instructions in Restoring Data Using a Cloud Server Backup and Using a Backup to Create an Image.
