Updated on 2026-11-26 GMT+08:00
Installing the Agent
Before enabling database server backup, you also need to install the Agent on your ECSs.
If Agent is not installed on servers, database server backup will fail, but a common server backup can be performed instead. To ensure a successful database server backup, download and install the Agent first.
Operation Instructions
  • Database server backup is available only for x86-based ECSs. It is not available for Kunpeng-based ECSs.
  • During Agent installation, the system runs the installation program as the rdadmin user. To improve O&M security, change the user rdadmin's password of the Agent OS regularly and disable this user's remote login permission. For details, see Changing the Password of User rdadmin.
  • Table 1 lists the OSs that can have the Agent installed. Only Windows OSs in English can have the Agent installed.
    Table 1 OSs supporting the Agent
    Database
    OS
    Supported Versions
    SQL Server 2008
    Windows
    Windows Server 2012, 2012 R2, 2019 for x86_64
    SQL Server 2012
    Windows
    SQL Server 2019
    Windows
    Windows Server 2019 for x86_64
    SQL Server 2014/2016/EE
    Windows
    Windows Server 2016 Datacenter for x86_64
    MySQL 5.5/5.6/5.7
    Red Hat
    Red Hat Enterprise Linux 6 and 7 for x86_64
    SUSE
    SUSE Linux Enterprise Server 12, 15 SP1, 15 SP2 for x86_64
    CentOS
    CentOS 6 and 7 for x86_64
    EulerOS
    EulerOS 2.2, 2.3 for x86_64
    HANA 1.0/2.0
    SUSE
    SUSE Linux Enterprise Server 12 for x86_64
    For Windows servers, ensure that Volume Shadow Copy is running properly. Otherwise, the backup will fail.
  • Table 2 lists the supported SHA-256 values.
    Table 2 SHA-256 values
    Package Name
    SHA-256 Value
    Cloud Server Backup Agent-CentOS6-x86_64.tar.gz
    f0c59ccb4443bcb6e874bf6e3c574914f9f8b27f3f7379e2d81956a9972802f3
    Cloud Server Backup Agent-CentOS7-x86_64.tar.gz
    2d3028cb794e1699bae9f65746a60ae99be17d5c4c5e7ebe6b45ff261db9c3c7
    Cloud Server Backup Agent-EulerOS2-x86_64.tar.gz
    4fb4cf9cb6f5b0e6c13d8ad8bf928754cb95332ee645a97fd0bb3fcbeb53d003
    Cloud Server Backup Agent-RedHat6-x86_64.tar.gz
    6ae3838fb5644f0f47282c211fe20c6b57a7c5c1d683cd5a1f55860d259b2054
    Cloud Server Backup Agent-RedHat7-x86_64.tar.gz
    40fa68a808d9da04672678b2773e3345ea6c9dee3c17d598acb66a023cc5cacc
    Cloud Server Backup Agent-SuSE11-x86_64.tar.gz
    346cc9f1fc0a41a817abb2db61e657a4d615449e13bc46f1c1cfbadc0b281f47
    Cloud Server Backup Agent-SuSE12-x86_64.tar.gz
    625279b9c9d17ddcc4210b78242efebacdad73f808b86754659d243ece85a400
    Cloud Server Backup Agent-WIN64.zip
    b7b2067ac89f1fec635d82e3fe2ea794ce6482f9880838f34924b383be44ac4e
During Agent installation, the system automatically enables a port in the range of 59526 to 59528 on the ECS. If port 59526 is in use, it tries 59527 and then moves to the next available port in the range.
  • The username and password for logging in to the console have been obtained.
  • The security group has been configured.
  • The Agent Status of the ECS is Not installed.
  • If you use Internet Explorer, you need to add the websites you will use to trusted sites.
