Help Center>
Cloud Backup and Recovery>
User Guide>
Appendix>
Agent Security Maintenance>
Changing the Password of User rdadmin
Updated on 2024-03-15 GMT+08:00
- To improve O&M security, you are advised to change the user rdadmin's password of the client OS regularly and disable this user's remote login permission.
- In Linux, user rdadmin does not have a password.
- This section describes how to change the password of user rdadmin in Windows Server 2012. Change the password according to actual situation in other versions.
- The username and password for logging in to the console have been obtained.
- The username and password for logging in to a Windows ECS have been obtained.
- Go to the ECS console and log in to the Windows ECS.
- Choose Start > Control Panel. In the Control Panel window, click User Accounts.
- On the displayed User Account Control dialog box, select rdadmin and click Reset Password.
- Enter the new password and click OK.
- In Task Manager, click the Services tab and then click Open Service.
- Select RdMonitor and RdNginx respectively. In the displayed dialog box, select Login, change the password to the one entered in Step 4, and click OK.
Parent topic: Agent Security Maintenance
