Uninstalling the Agent
This section describes how to uninstall the Agent when application-consistent backup is no longer needed.
The username and password for logging in to an ECS have been obtained.
Uninstalling the Agent for Linux
- Log in to the ECS and run the su -root command to switch to user root.
- In the home/rdadmin/Agent/bin directory, run the following command to uninstall the Agent. Figure 1 displays an example. If the word successfully in green is displayed, the Agent is uninstalled successfully.
sh agent_uninstall_ebk.sh
Uninstalling the Agent for Windows
- Log in to the ECS.
- In the Installation path/bin directory, double-click agent_uninstall_ebk.bat. The window for uninstalling the Agent is displayed.
After the uninstallation is complete and successful, the window will be automatically closed.
Figure 2 Agent uninstalled successfully from Windows
