Updated on 2026-07-09 GMT+08:00
Deleting a Backup
You can delete unwanted backups to reduce space usage and costs.
If a backup has been used to create an image, the backup cannot be deleted. In this case, delete the image first by following the instructions in Deleting Images.
CBR supports manual deletion of backups and automatic deletion of expired backups. The latter is executed based on the backup retention rule in the backup policy. For details, see Creating a Backup Policy.
  • Backups are not stored on a server. Deleting backups has no impact on the server performance.
  • If a backup already exists while the next incremental backup task is in progress, any attempt to delete the existing backup will be blocked. You must wait until the incremental backup finishes before performing the deletion.
  • CBR automatically creates snapshots during backup and retains the latest snapshot for each disk. If a disk already has a backup, after another backup, the old snapshot will be deleted and the latest one will be retained.
  • There is at least one backup.
  • The backups to be deleted are in the Available or Error state.
Billing
  • You are billed for the storage space and the data traffic generated if backup replication is used. The prices for the storage space vary with vault types. The vault capacity remains unchanged after backups are deleted, so the charges remain unchanged.
  • For details about billed items, see CBR Billing. For details about pricing, see CBR pricing details.
  1. Log in to the CBR console. Click in the upper left corner and select a region.
  2. Click the Backups tab. Locate the desired backup. For details, see Viewing a Backup.
  3. Choose More > Delete from the Operation column. Alternatively, select the backups you want to delete in a batch and click Delete in the upper left corner to delete them.
    Figure 1 Deleting a backup
  4. In the displayed dialog box, confirm the information, enter DELETE, and click OK.
    Return to the backup list. If the target backup no longer appears, it was deleted successfully.
Helpful Links
