- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Service Resilience
COC provides a three-level reliability architecture and uses intra-AZ instance disaster recovery (DR), dual-AZ DR, and periodic backups to ensure service durability and reliability.
Reliability Solution |
Brief |
Intra-AZ instance DR |
In a single AZ, COC implements instance DR in multi-instance mode and quickly rectifies faults to continuously provide services. |
Multi-AZ DR |
COC supports cross-AZ DR. If an AZ is faulty, COC services are not interrupted. |
Data DR |
Data is periodically backed up for data DR. |
