Updated on 2026-07-29 GMT+08:00
Application Scenarios
O&M BI Dashboard
The dedicated O&M BI dashboard caters to various O&M roles, aiding in optimization, insight generation, and decision-making.
Rich metrics: COC provides over 30 preset O&M metrics, delivering insights into your cloud resources across seven-perspective BI dashboards and a comprehensive enterprise-grade O&M sandbox. The O&M sandbox and the BI dashboards help you understand your service O&M situation from both bird's eye and ground level views in real time.
Figure 1 O&M BI dashboard
Full-Lifecycle Resource Management
Full-lifecycle resource management is available, and includes actions such as resource defining, requesting, provisioning, O&M, changing, configuration, renewal, and recycling; building a unified resource management center.
  • Full-lifecycle management: eliminates breakpoints across the entire user resource management journey, ensuring smooth user resource management and efficient O&M.
  • Resource management center: enables visualized management of your resources from a global perspective, and supports multi-cloud and cross-account centralized O&M.
Figure 2 Full-lifecycle resource management
Change Risk Control and Trustworthy Operations
Management and control models that integrate Huawei SRE best practices in secure production provide you with trustworthy, stable, and reliable O&M capabilities.
  • Operations trustworthiness: ensures operational security before, during, and after changes, is supported by personnel risk assessment capabilities, and offers high-risk command alerts, and automated inspection.
  • AI-powered risk assessment: The intelligent interception algorithm for high-risk commands is used to mitigate operation risks.
Figure 3 Change risk control and operations trustworthiness
Standardized Fault Management
The standardized fault management process and war room enhance efficient fault synergy and rapid fault recovery.
  • Standard process: provides a standardized troubleshooting process on Huawei Cloud. Bolstered by response plans and the war room-based synergy of O&M engineers, R&D teams, and other personnel, this standardized process helps you handle faults encountered with ease.
  • O&M knowledge base: enables the swift handling of faults. A rich repository of O&M knowledge, derived from handling historical faults and the accumulation of experience in handling unknown faults, increases efficiency during fault handling process.
Figure 4 Standardized fault management
Intelligent Chaos Drills
Full-stack chaos engineering solutions enable you to quickly evaluate the potential resilience risks of applications and continuously monitor application architectures.
  • E2E chaos engineering solutions: provide E2E chaos drill capabilities based on your service scenarios from four dimensions: risk analysis, contingency plans, drill execution, and drill review.
  • Failure mode library: introduces the methodology of analyzing fault scenarios for DR, and leverages Huawei Cloud SREs' years of accumulated experience in fault handling through the failure mode library.
Figure 5 Intelligent chaos drills
